50" Mower Deck Questions
9 replies to this topic
#1 nycub122 OFFLINE
nycub122
  • 25 Thanks
  • 74 posts
Posted July 22, 2013 - 05:47 AM
I am in the process of rebuilding a 50" mower deck (09JC9838) and need some help.
Are there other sources for the idler pulley spring and spindle bearings, other than New Holland?
Idler spring ($25) and bearings ($35/ea) seem a LITTLE pricey to me.
Any suggestions?
Pictures to follow shortly.
Thanks
GEL
  • larryd said thank you
#2 KennyP ONLINE
  • 38,385 Thanks
  • 45,935 posts
Posted July 22, 2013 - 06:00 AM
I haven't had to find bearings as yet. Do you have a local bearing supply? Maybe a lot cheaper there!
#3 nycub122 OFFLINE
nycub122
  • 25 Thanks
  • 74 posts
Posted July 22, 2013 - 06:05 AM
KennyP;
Thanks for the reply. Haven't checked local bearing suppliers, yet.
Also, I see that 2 types of spindle housings are used, the 6 hole aluminum housing was dropped in favor of the 4 hole steel housing. Any ideas as to why, and which is better?
Also, any sources for the spindle pulleys?
GEL
#4 superaben OFFLINE
superaben
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted July 22, 2013 - 06:14 AM
The idler springs for most decks can be purchased at a good hardware store, as long as you don't mind bending wire to make it work.
Spindle pulleys, keyed, can be found at an industrial supply store or a good farm/hardware store.
Ben W.
#5 KennyP ONLINE
  • 38,385 Thanks
  • 45,935 posts
Posted July 22, 2013 - 06:50 AM
I found a pulley for my 09JC9835 deck at TSC. Here's a thread on it's refurb!
#6 firstgen89sho OFFLINE
firstgen89sho
  • 82 Thanks
  • 90 posts
Posted July 22, 2013 - 11:18 AM
Spindle bearings, I used SKF # 6205-2RSJ, I still have the box sitting on my bench here.
#7 nycub122 OFFLINE
nycub122
  • 25 Thanks
  • 74 posts
Posted July 29, 2013 - 05:35 AM
Thanks for the replys.
Does anyone have an opinion about the spindle housings?
I have both the aluminum and steel housings. Which is the better ones to use in my rebuild?
GEL
#8 firstgen89sho OFFLINE
firstgen89sho
  • 82 Thanks
  • 90 posts
Posted July 29, 2013 - 01:10 PM
I'd use the steel ones over the aluminum, less likley to get damaged
#9 Skip3 OFFLINE
Skip3
  • 1 Thanks
  • 2 posts
Posted August 22, 2013 - 03:51 PM
I found a part number on MTF for bearings for the steel spindle, "E1ADKN7600A". I googled that number and found several sources, and one place had a price around $4.50. They are referring to them as Fordson pilot bearings, but their dimensions look similar to what I think mine are, if I can ever get the outside pulleys off. (And I'm not going to attempt that until I have replacements in hand.)
#10 nycub122 OFFLINE
nycub122
  • 25 Thanks
  • 74 posts
Posted August 25, 2013 - 05:26 AM
Measured the spindle on my 50" deck
Spindle OD=.9800"
Pulley ID=.9830"
Hope that will help
GEL
