Case 446 Repower - Kohler M18?
9 replies to this topic
#1 jdslednut ONLINE
jdslednut
  • 678 Thanks
  • 851 posts
Posted July 21, 2013 - 08:08 PM
If you've seen my other thread you'll know I've had a bad day.  My new baby has a broken rod and I don't want to shell out the big bucks for an Onan rebuild.
Has anyone repowered a 446 or similar Case with a Kohler M18?  I have one in my Snapper LT that should be in great shape.  I just don't want a 2 year process before I get it done and I don't want to hire a machine shop to make some kind of crazy adapter to drive something.
Just wondering what mods would be necessary and if it is a huge job or one that could be done reasonably.
Thanks!
  • larryd said thank you
#2 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted July 21, 2013 - 08:29 PM
I can't help you but I'm sure some one on this sight has great knowledge on this . Good luck
larryd
#3 Mjoe7 OFFLINE
Mjoe7
  • 173 Thanks
  • 172 posts
Posted July 21, 2013 - 11:38 PM
Thanks!
It's been done. It's a slight down grade, but all it takes is a crank shaft that is the same size and you'd have to look into fitting the front pto.
The best way to know is to just start doing it and see what you run into.
Here is a pic of one someone did. I wish I had detailed pics for you, but its better than nothing.
Good luck.
  • jdslednut said thank you
#4 braxx OFFLINE
braxx
  • 20 Thanks
  • 45 posts
Posted July 22, 2013 - 11:34 AM
I have Case/Ingersoll 446 and 448 also a Massey Ferguson 318gtx (basically a Ingersoll 4018) . The MF318gtx has a kohler m18. I like that engine more than my Onans. It runs PERFECT and isn't as finicky as my onans. That being said, I wouldn't try to reinvent the wheel. I would replace your Onan with another Onan just for ease of fitment etc.
Sent from my S3
Edited by olcowhand, July 22, 2013 - 11:50 AM.
#5 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted July 22, 2013 - 12:22 PM
I would start with pulling the Onan apart first, see how much damage was done, who knows you might be surprised.
#6 dhiesel OFFLINE
dhiesel
  • 22 Thanks
  • 24 posts
Posted August 12, 2013 - 03:05 PM
I had a my Sears running on 1 cyl. tore the engine down, replaced the connecting rods and pistons  (used), put new rings and gaskets on.
It's running today. I was meticulous on flattening my fuel pump, and carb surfaces on the rebuild, tie straps on my vacum lines - after no operation in 4 months it starts right up.
#7 WpgJetFan OFFLINE
WpgJetFan
  • 18 Thanks
  • 35 posts
Posted April 05, 2017 - 01:50 PM
You would be further ahead using a clutch from a Kohler (direct bolt on)... mounting up to you for engine  Brian
#8 KennyP ONLINE
  • 38,273 Thanks
  • 45,877 posts
Posted April 05, 2017 - 02:08 PM
This is an old thread.
#9 jdslednut ONLINE
jdslednut
  • 678 Thanks
  • 851 posts
Posted April 05, 2017 - 10:37 PM
Yeah, but I'm still around!
#10 WpgJetFan OFFLINE
WpgJetFan
  • 18 Thanks
  • 35 posts
Posted April 06, 2017 - 08:27 AM
I've done this install (Kohler Magnum 16 in for K241 10hp into a Case 220) - no issues except compensating for wide base block with plate to allow narrow base plate to bolt up.  The Onan to Kohler change is probably better served getting a Kohler frame rather then butchering the Onan frame.... if availalble.  You'd need the Kohler pump mounting plate and the Kohler clutch to go with the Magnum swapping from Onan.  I'm a Kohler guy but agree the Onan rebuild if at all possible is the least headache... (but you can sell the Onan and Onan components to compensate cost)  In the end - your choice.  Magnum 16 gives unbelievable power and the breakerless ignition is great starting at 35 below (in Manitoba) Brian
  • jdslednut and My3kidsfather have said thanks
