Jacobsen 53500
4 replies to this topic
#1 Rock farmer ONLINE
Rock farmer
  • 1,229 Thanks
  • 1,245 posts
Posted July 21, 2013 - 07:18 PM
Today, I turned my attention to my big jake. I'd been rather dreading taking the exhaust manifold off! Broken bolts, rounded nuts! Ect. Ect.! But, it went really well! Nothing broke, and every thing went well. I learned some things and bought some parts to fix the problems I found. I don't know if I found my main problem of it smoking. But, what I found definitely needed to be fixed, i am going to test the fuel pump to see if it is leaking gas into the crank. But, it is really sloppy, so I'm hoping that that is my biggest problem.
It had a broken exhaust manifold. And an oil leak on that side. May still be blow by on the rings. Or, a bad valve sleeve?
Joe
  • larryd said thank you
#2 KennyP ONLINE
  • 40,080 Thanks
  • 46,744 posts
Posted July 21, 2013 - 07:41 PM
Just out of curiosity, has this engine sat a lot? Could be stuck rings if so. Could be some carbon build up if it is smoking a lot.
#3 Rock farmer ONLINE
Rock farmer
  • 1,229 Thanks
  • 1,245 posts
Posted July 21, 2013 - 07:55 PM
I don't know how long it sat. But, I did remove the heads and de-carb them. Pistons didn't seem too sloppy. But, I'm not ruling out a ring job! Just thinking something else, as it didn't smoke when I got it.
Joe
#4 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted July 21, 2013 - 08:40 PM
Maybe it won't be as bad as you think
larryd
  • Rock farmer said thank you
#5 T Guiles OFFLINE
T Guiles
  • 953 Thanks
  • 749 posts
Posted July 21, 2013 - 10:49 PM
wishing you the best on fixing your jake, hope it's something small, easy, and cheap to fix
