8183T Not Starting After Smoking After Short Run
4 replies to this topic
#1 DonaldO OFFLINE
DonaldO
  • 1 Thanks
  • 1 posts
Posted July 21, 2013 - 06:55 PM
We have an 8183T with the ONAN ENGINE after running good for thirty years it is now giving up the ghost.  We replaced the oil pump (after looking all over for a replacement) then this spring it ran for about an hour and started smoking badly.  I parked it and the next day tried to start it but there doesn't seem to be any spark.  Could it be a bad coil and if so are we finished as parts don't seem to be available for the ONAN.
  • larryd said thank you
#2 KennyP OFFLINE
  • 40,900 Thanks
  • 47,099 posts
Posted July 21, 2013 - 07:08 PM
Which Onan is this? There are still parts available to rebuild most Onan's. Just not cheap!
#3 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted July 21, 2013 - 08:45 PM
Could be it lost compression
larryd
#4 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted July 21, 2013 - 08:54 PM
Welcome to the forum!
Don't give up on the old Onan yet.  Gravely always picked a good brand for their machines.
I imagine, unless you have already tested by isolating the coil from the ground wire, you have a tractor problem: there's always a good chance for a bad safety switch of some sort.
Ben W.
#5 MH81 OFFLINE
  • 29,978 Thanks
Posted July 21, 2013 - 11:03 PM
:ditto:
There are lots of reasons for lost spark, and even if you have a bad module, there are some aftermarket/retrofit ideas.
A model of onan will help the guru's
Good luck
