Front Axle Pin Question
13 replies to this topic
#1 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted July 21, 2013 - 06:00 PM
Can anyone help me on removing the play in the front axle of my Allis 416. it seems to fit well on the axle, just not in the races of the frame. video below, Thanks, Mike
http://s1197.photobu...html?sort=3&o=0
  • larryd said thank you
#2 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,015 Thanks
  • 9,644 posts
Posted July 21, 2013 - 06:09 PM
I'm not an expert on Allis, but I would say, if it is loose in the frame you will have to bore out an rebush it.
  • larryd and OkieGt have said thanks
#3 olcowhand ONLINE
  • 40,384 Thanks
  • 31,180 posts
Posted July 21, 2013 - 06:17 PM
There are bushings in front & rear, part #1608341  Available at Jacks' Small Engines, and other places also of course.  Expensive, but will tighten things up.  With the dimensions, you may have a buddy that can turn you some in a lathe from brass or bronze.
Part Number Description Supercedes - Whats This? Price Order Here
Simplicity
PN# 1608341SM
More Info BEARING 1.265IDX1.505 PN#: 1608341
has been superceded
to PN# 1608341SM
Our Price: $17.95
Qty:  1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
  • New.Canadian.DB.Owner, LilysDad, larryd and 1 other said thanks
#4 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted July 21, 2013 - 06:36 PM
Simplicity
PN# 1608341SM
has been superceded
to PN# 1608341SM
Our Price: $17.95
Am I to under stand they are 17.95 EACH, plus shipping! WOW. could they be the same size as the wheel bearing races?
#5 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted July 21, 2013 - 06:38 PM
Love your quote, nope there is nothing powerful enough to separate us from Him and His Love
  • LilysDad and larryd have said thanks
#6 olcowhand ONLINE
  • 40,384 Thanks
  • 31,180 posts
Posted July 21, 2013 - 06:41 PM
These are bushing type, likely sintered bronze.  Yes, $18 EACH!  Ouch!
#7 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted July 21, 2013 - 07:11 PM
How would you recommend I remove the bushing from inside the tractor frame , large socket and hammer?
#8 olcowhand ONLINE
  • 40,384 Thanks
  • 31,180 posts
Posted July 21, 2013 - 07:17 PM
I'd use a hacksaw blade to cut a slice through one side of the bushing down to the steel.  Then it'll knock out easily, with socket, or just catch the edge with a chisel.
#9 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted July 21, 2013 - 07:25 PM
Thanks, Dan, I just tried to use a socket to punch it out, but its worn so thin I cant get any of it, chisel or hacksaw it is. I'll probably buy the ones from Jack and save my self some trouble, I had enough trouble finding a machine shop within a hundred miles that had a reamer
#10 olcowhand ONLINE
  • 40,384 Thanks
  • 31,180 posts
Posted July 21, 2013 - 07:28 PM
When I refreshed my 416, these bushings were completely gone, so it saved me the trouble of removing the remains.  Luckily the pin hadn't worn into the steel hardly at all.
#11 JDBrian OFFLINE
  • 9,613 Thanks
  • 14,144 posts
Posted July 21, 2013 - 07:50 PM
The hacksaw blade trick works well. Much easier and less likely to damage things than the brute force method. I've used it successfully several times on the 317 restoration.
#12 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted July 21, 2013 - 08:39 PM
I tried the hacksaw trick, I didn't even scratch the metal, I decide to check the measurement, it mics to1.470, could be bigger, I cant see to hold it in the right place. there is a slight ridge/lip inside the hole, now I'm wondering if my axle bearings are gone as well. How can I tell?
#13 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted July 21, 2013 - 09:06 PM
I had to rebuild my axle on my 917H but neighbour had a machine shop so we done it all and saved $$$$
larryd
  • OkieGt said thank you
#14 OkieGt OFFLINE
OkieGt
  • 1,428 Thanks
  • 1,447 posts
Posted July 21, 2013 - 09:24 PM
larryd
917 axle is different from the 416, even different from the 300 series, and the 700 series. The 3400 series may be the closest
