New guy here
48 replies to this topic
#31 Bolens 1000 ONLINE
  • 17555 Thanks
  • 18864 posts
Posted November 17, 2010 - 04:56 PM
#32 Bolens 1000 ONLINE
  • 17555 Thanks
  • 18864 posts
Posted November 17, 2010 - 05:01 PM
Look at part #111
Thats the drive cone
It may be frozen to the shaft and not letting you thread the nut all the way...
#33 awol OFFLINE
awol
  • 78 Thanks
  • 343 posts
Posted November 17, 2010 - 05:29 PM
I'm sorry Dr Bolens I think I'm not identifying where the movement is properley, It's the hub assembley p/n 1716511 where the oil seal is I think. Dam noobie!!! see original pic in post.
#34 Bolens 1000 ONLINE
  • 17555 Thanks
  • 18864 posts
Posted November 17, 2010 - 05:43 PM
Yeah thats what I'm referring to. I performed this adjustment recently on one of mine. It had some slop just as you are describing,It should tighten right up if you turn in those nuts on each end.
#35 mjodrey OFFLINE
  • 2375 Thanks
  • 13481 posts
Posted November 17, 2010 - 05:53 PM
Hey Brian,I think you're going to get
"stuck" with that Dr.Bolens moniker ,but it fits you to a Tee. LOL
#36 Bolens 1000 ONLINE
  • 17555 Thanks
  • 18864 posts
Posted November 17, 2010 - 06:01 PM
This just popped into my mind...
Mabye you need to add some shim's to the hub... #'s 59 and 60
http://sonnys_bolens...eframe/1053.pdfUntitled.jpg
#37 Bolens 1000 ONLINE
  • 17555 Thanks
  • 18864 posts
Posted November 17, 2010 - 06:05 PM
I believe your right LOL
#38 awol OFFLINE
awol
  • 78 Thanks
  • 343 posts
Posted November 17, 2010 - 06:08 PM
I will try to take a video of it tomorrow and show you exactly whats going on. I don't want to waste anymore of your time as I feel so stupid going on about this problem. I know you guys are here to help, and I appreciate all you do.
#39 Bolens 1000 ONLINE
  • 17555 Thanks
  • 18864 posts
Posted November 17, 2010 - 06:17 PM
It's no bother at all
I'm sure once you get pics/video we'll be able to pin point the problem...
#40 awol OFFLINE
awol
  • 78 Thanks
  • 343 posts
Posted November 17, 2010 - 06:30 PM
Thanks Bolens 1000, Mjodrey is funny!! If that is the problem is that something i can do myself? Im afraid to go that far right now as i probadly would need some parts. And not sure where to get any in my area.
#41 Bolens 1000 ONLINE
  • 17555 Thanks
  • 18864 posts
Posted November 17, 2010 - 06:40 PM
Your main place to find parts will probably be on the web. There is a sticky posted with some Bolens parts suppliers. The good thing is there are still many parts readily available for these.
From what I can tell this should be a simple fix and you probably will only have to take the one hub apart.
#42 awol OFFLINE
awol
  • 78 Thanks
  • 343 posts
Posted November 17, 2010 - 06:55 PM
I guess no parts supplier in Canada? To access the bronze bearing you go through the bottom or just pull the hub and not the axle. would i need to replace the oil seal, thrust race and bearing as well?
#43 Bolens 1000 ONLINE
  • 17555 Thanks
  • 18864 posts
Posted November 17, 2010 - 07:09 PM
This can all be done without taking the cover from the top and bottom off.
If your careful you wont need to replace the seal but since you got it off you mine as well. It's been a little while since I had a tranny appart but I believe you can just pull the hub off and do the work there,
I think Bolens parts dealers in Canada are slim
#44 awol OFFLINE
awol
  • 78 Thanks
  • 343 posts
Posted November 17, 2010 - 07:30 PM
I guess i will just have to suck it up and pay the shipping, the guy i bought it from said that these tractors are built like a tank and should have no problems with it. It starts and runs fine, i had to put a new battery in thats all so far!!! I don't think it is charging the battery because the battery went dead today not sure if it is because i've been not running it for any length of time or something else. I will see about getting the parts before i open it up and try to solve this problem.I do appreciate all your help.
#45 Bolens 1000 ONLINE
  • 17555 Thanks
  • 18864 posts
Posted November 17, 2010 - 07:35 PM
Like I said earlier, you should be fine to use it as is for the rest of the season so you have something to move snow.
The guy was right when he said these were built like tanks!
Another possibility you may consider is looking for another used Tranny. Most of the time your better off picking up another tranny for $75-$100 instead of buying over $100 in parts...
