New guy here
48 replies to this topic
#16 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted November 15, 2010 - 06:37 PM
Yes, tightening the nuts will take up slack front to back as well.
#17 awol OFFLINE
awol
  • 78 Thanks
  • 343 posts
Posted November 15, 2010 - 06:46 PM
Thanks again!! i will try that, i know the left side is tighten hand tight but the right dose'nt move, it might be siezed. Iwill check tomorrow when i have more light.
#18 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted November 15, 2010 - 06:51 PM
The posi Loc may be stuck also so you may want to raise both wheels off the ground and once you get both nuts loose spin the wheels around and that will disengage the lock if it was stuck.
Keep us posted on what you find out :thumbs:
#19 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted November 15, 2010 - 06:54 PM
http://sonnys_bolens.../1253-02-OM.pdf
Read page 11 to see more of what I described above
#20 awol OFFLINE
awol
  • 78 Thanks
  • 343 posts
Posted November 15, 2010 - 07:05 PM
I will let you know thanks so much. I was just looking at the manual and noticed that there is only one castle nut p/n 1109653 and it is on the right(the one that is siezed)and with a cotter pin which is missing.
#21 awol OFFLINE
awol
  • 78 Thanks
  • 343 posts
Posted November 15, 2010 - 07:22 PM
Welcome AWOL,
Where are you missing from, LOL
Lots of great people here, so just ask your questions and somebody will be able to help you.
Great to have you here, Brian
The wife LOL to much tractor talk
#22 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted November 15, 2010 - 07:28 PM
Just looked at the parts list and I guess its called a Hex nut on the left side.
http://sonnys_bolens...eframe/1453.pdf
#23 awol OFFLINE
awol
  • 78 Thanks
  • 343 posts
Posted November 15, 2010 - 07:33 PM
Your right, so should i tighten the castle nut?
#24 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted November 15, 2010 - 07:38 PM
I'd do the castle nut first and see if that fixes your problem
#25 awol OFFLINE
awol
  • 78 Thanks
  • 343 posts
Posted November 15, 2010 - 07:49 PM
Will do, I will let you know tomorrow if it helps. No light in shelter yet just put it up.
#26 awol OFFLINE
awol
  • 78 Thanks
  • 343 posts
Posted November 17, 2010 - 11:25 AM
I got the castle nut off no problem and installed a new cotter pin. Still alot of play at the point i decribed earlier.I'm at loss i just hope it will last the winter as i plan on restoring it in the spring.
#27 WQDL753 OFFLINE
WQDL753
    Bolensholic
  • 59 Thanks
  • 301 posts
Posted November 17, 2010 - 02:09 PM
Did you do both sides? The manual says left side must be done first, then do the right.
This won't get rid of all the backlash, but should improve it.
#28 awol OFFLINE
awol
  • 78 Thanks
  • 343 posts
Posted November 17, 2010 - 02:16 PM
Yes I did the left side first! and still about a 1/4 to 1/2 inch play only on the left side front to back or up and down if the wheels are off the ground.
#29 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted November 17, 2010 - 04:38 PM
hmm that is wierd... I never seen them have that much play after the adjustment...
Can you get a better pic of the play?
I think you'll be ok if you leave it as is for now.
#30 awol OFFLINE
awol
  • 78 Thanks
  • 343 posts
Posted November 17, 2010 - 04:54 PM
Yes, I will take one tomorrow with the wheel off. It's to dark now and 55 kilometer winds!!!!!!!! I guess I'd better bolt the shelter down. I just moved from the BIG city Ottawa the capitol of Canada to rural Smiths Falls Ontario, on just about an acre. So things are still up in the air rite now. hopefully not my shelter.
