Bought Couple K181's, Not Sure What I Got
5 replies to this topic
#1 glgrumpy ONLINE
  • 8,561 Thanks
  • 7,881 posts
Posted July 19, 2013 - 11:22 PM
At Show picked up couple K181's. One is a starter/gen and one is pull start. Thinking the Start/gen may be from wheelhorse, and the pull one from a Troy-built tiller maybe?
The start/gen one:
K181S    S is electric start?
Spec  301080
Serial  A18115     Not sure why the A?
Pull start:
K181T     T is pull start?
Spec 307074
Serial 8332977    There is a serial tag on front of cover, probly frm the unit it powered of 41920.  Troybuilt put those there?
SO, what have I got?
  • boyscout862 and larryd have said thanks
#2 KC9KAS ONLINE
KC9KAS
  • 5,328 Thanks
  • 4,672 posts
Posted July 20, 2013 - 11:53 AM
The starter/generator...are you sure the serial number 301080 isn't 30108D.
The 30108D is on a1966 856 4 speed, and 876 automatic, and 1968 Commando 8, 4 speed.
#3 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted July 20, 2013 - 04:03 PM
TroyBilt didn't use a K181, they used a K161.
#4 glgrumpy ONLINE
  • 8,561 Thanks
  • 7,881 posts
Posted July 22, 2013 - 06:52 AM
KC9 that was 30108 C when I went out and looked again with the tin Off the engine.  That mean anything? I took couple of pix. Lots of stuff missing or modified on both engines. The pull start one is the best internal shape with compression and such.
#5 KC9KAS ONLINE
KC9KAS
  • 5,328 Thanks
  • 4,672 posts
Posted July 22, 2013 - 06:20 PM
I do not see any WH with the number 30108 C.
#6 dodge trucker ONLINE
dodge trucker
  • 2,299 Thanks
  • 3,015 posts
Posted August 14, 2013 - 05:27 PM
they actually used BOTH depending on year of tiller...  later they used the M8 which is the same engine as a 181 only with elect ignition instead of points
