Mf #12 Rear Cast Wheel Weights.......work On Mf 1655?
2 replies to this topic
#1 Luke OFFLINE
Luke
  • 183 Thanks
  • 399 posts
Posted July 19, 2013 - 09:41 PM
Just wondering if the old red cast two piece wheel weights off a #12 will work in the rims of a 1655? Thanks
  • larryd said thank you
#2 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted July 19, 2013 - 09:56 PM
Yes
#3 JDBrian OFFLINE
  • 9679 Thanks
  • 14162 posts
Posted July 20, 2013 - 04:34 AM
The 12" wheels are normally a standard size as far as the mounting bolts. I did discover recently that my 1983 JD 314 had a slightly narrower spacing than my 2005 JDx475. I was able to adapt my wheel weight brackets to the 314 by using 7/16" bolts to mount them instead of 1/2" so the difference wasn't much but it was there. So there could be some slight difference in old wheels and new.
