Thank you very much for this service to all the members. I inherited a L130 which had not been run for about 7 years. It has 170 hours The engine is a Kohler,two cylinder V, 23 hp. I changed plugs, air filter, fuel filter,fuel pump. If I spray a little starter fuel into the carb , it runs for a few seconds. I blew out the lines going to the gas tank,fuel pump. When I crank the engine, only a small amount of gas is seen in the fuel filter. I have not taken the carb off or done anything to it . It will not sart
I believe this is a fuel delivery problem. Is this a vacum problem to the fuel pump? Is it an issue with the carb ? Help......I a little smart, but clearly not smart enough. Thank you
