What Would Be A Good Puller A Cub Cadet 1100 Or A Cub Cadet 100
16 replies to this topic
#1 searspullingtractor OFFLINE
searspullingtractor
  • 34 Thanks
  • 103 posts
Posted July 19, 2013 - 02:45 PM
does anyone with these
#2 Kyocum OFFLINE
Kyocum
  • 299 Thanks
  • 424 posts
Posted July 19, 2013 - 03:29 PM
Either or as long as they are set up correctly. I would lean torward the 100 myself.
#3 searspullingtractor OFFLINE
searspullingtractor
  • 34 Thanks
  • 103 posts
Posted July 19, 2013 - 04:03 PM
thanks
#4 OkieGt OFFLINE
OkieGt
  • 1,432 Thanks
  • 1,447 posts
Posted July 19, 2013 - 04:07 PM
The 1100 was a 11hp briggs engine, the 100 was a 10 hp Kohler, size and weight I think the 100 is the better geared option, If I'm not mistaken the 100 was also a vertical shaft, in which case not near as good IMHO
EDIT : Sorry Guys where I said the 100 was a vertical shaft was supposed to say 1100, but that was wrong as well. Blind in one eye, cant see out of the other, your lucky you dont have to share the road with me.
Edited by OkieGt, July 19, 2013 - 07:48 PM.
#5 searspullingtractor OFFLINE
searspullingtractor
  • 34 Thanks
  • 103 posts
Posted July 19, 2013 - 04:21 PM
I am looking for any cub cadet 10hp gear drive for next year for pulling
#6 OkieGt OFFLINE
OkieGt
  • 1,432 Thanks
  • 1,447 posts
Posted July 19, 2013 - 04:28 PM
1100's are really rare, 100 are real collectable, some well over 600-800, I would look for a 102 10hp or a 122 12hp , very cheap and even better for a puller model
#7 searspullingtractor OFFLINE
searspullingtractor
  • 34 Thanks
  • 103 posts
Posted July 19, 2013 - 04:47 PM
I am just looking for something gear drive and I can get it worked
#8 Kyocum OFFLINE
Kyocum
  • 299 Thanks
  • 424 posts
Posted July 19, 2013 - 07:13 PM
Cub Cadet didn't make a vertical shaft garden tractor. Lawn tractors were the only cubs with vertical shaft on the engine. I also think the 1100 had a peerless rearend which is less desirable than the cast units.
#9 old149 OFFLINE
old149
  • 38 Thanks
  • 21 posts
Posted July 19, 2013 - 07:37 PM
I using a gilson with horizontals 16hp flat head ring and pion rear end very low end engine lots of low end torque
cub cadet kohler engine are horizontals shaft
old149
  • OkieGt said thank you
#10 OkieGt OFFLINE
OkieGt
  • 1,432 Thanks
  • 1,447 posts
Posted July 19, 2013 - 07:45 PM
your right the Briggs 11hp engine was a horizontal shaft, my mistake, I believe it was a first for cub to use a briggs in a garden tractor
#11 OkieGt OFFLINE
OkieGt
  • 1,432 Thanks
  • 1,447 posts
Posted July 19, 2013 - 07:48 PM
old149
yeah I made a typo
#12 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted July 19, 2013 - 09:56 PM
If you can find a cub 3 speed it will fit into the 1100 frame as far as I know. They used the same frame as the 1000 and the 1200 models since its considered a wide frame. What class do you plan on pulling in? The wide frames are good for heavier classes and the narrow frames are good for up to 14hp since you can play with more weight. Im using a 1200 series frame for the diesel I just relocated the front axle and extended the frame a few inches for the radiator and fan to fit. But its all preference.
#13 searspullingtractor OFFLINE
searspullingtractor
  • 34 Thanks
  • 103 posts
Posted July 19, 2013 - 10:11 PM
I got a cub cadet 1200 I will be repainting it
#14 old149 OFFLINE
old149
  • 38 Thanks
  • 21 posts
Posted July 20, 2013 - 07:38 PM
Hi no I said I am using a gilson with is a montgomery words gilson tractor co
You haft to remember your cub is haft mtd and what was left over from internalas stock
you need to find a 149 or 122 older real cubs with kohler with drive shafts
yes I know a 149 is hydrostatic  but it will pull the roof off the court house
Edited by old149, July 20, 2013 - 07:41 PM.
#15 OkieGt OFFLINE
OkieGt
  • 1,432 Thanks
  • 1,447 posts
Posted July 20, 2013 - 07:42 PM
MTD didnt acquire Cub Cadet until 1980 after the 145/1650 quietline series, then they acquired the red International line of tractors in 1985, cubs had drive shaft way into the 1990s, some still do, might want to recheck that book.
Edited by OkieGt, July 20, 2013 - 07:43 PM.
