D4-10 Restoration
187 replies to this topic
#1 olcowhand ONLINE
  • 40,335 Thanks
  • 31,169 posts
Posted February 20, 2010 - 12:43 PM
 This post has been promoted to an article
HERE
#2 tweidman OFFLINE
tweidman
  • 251 Thanks
  • 797 posts
Posted February 20, 2010 - 03:32 PM
Wow that splined shaft was straight at one time. How do you twist a shaft like that with a 10hp engine?
#3 olcowhand ONLINE
  • 40,335 Thanks
  • 31,169 posts
Posted February 20, 2010 - 06:55 PM
:D
Have heard of several with twisted off axles, so I believe many weren't hardened correctly. Or I could go with Wisconsin's being plain brutish engines.:D
#4 tweidman OFFLINE
tweidman
  • 251 Thanks
  • 797 posts
Posted February 20, 2010 - 08:01 PM
Are you using a rattle can or a gun? How do you keep your shop warm enough to paint?
I wish it was warm enough for me to paint....:mecry:
#5 NUTNDUN OFFLINE
  • 10,336 Thanks
Posted February 21, 2010 - 08:56 AM
Use rattle can primer anymore. Works just as good as bulk spray, unless filling imperfections. I use spot puTty for that anyway. Almost hit 60F here today! I did heat the shop a few degrees. I have a hanging propane shop furnace.
I would almost give anything for 60 degree weather right now. I am anxious to see the finished project :D :thumbs:
#6 tweidman OFFLINE
tweidman
  • 251 Thanks
  • 797 posts
Posted February 21, 2010 - 09:05 AM
We were in the 40's here... and I was thinking that was warm. My garage is not insulated and I have no way to heat it. Therefore, there is not much happening here with my tractors, even though I have a ton of work to do.
#7 olcowhand ONLINE
  • 40,335 Thanks
  • 31,169 posts
Posted February 21, 2010 - 10:12 AM
George, please don't hold your breath...it's gonna take a looong time on this one!
#8 NUTNDUN OFFLINE
  • 10,336 Thanks
Posted February 21, 2010 - 01:13 PM
Ok, I will try not to LOL
#9 mjodrey OFFLINE
Posted February 25, 2010 - 07:39 PM
Long time or not,I bet it will be nice when finished.
#10 Bolens 1000 ONLINE
  • 14,893 Thanks
  • 18,098 posts
Posted June 13, 2010 - 01:56 PM
Took a few pics of the innards of the engine. I have a NOS piston & rings to go into it. Hard to find parts, but if you keep a close watch on ebay & other places, you can snag them. Patience is the key.
Yep, the connecting rod and piston are expensive and hard to find New. I kept watching ebay and was able to snag a NOS connecting rod for $20!
Edited by olcowhand, June 13, 2010 - 02:09 PM.
hit edit instead of reply...sorry Brian
#11 olcowhand ONLINE
  • 40,335 Thanks
  • 31,169 posts
Posted June 13, 2010 - 02:08 PM
I gave no more than that for the piston & ring set!
#12 tractormike OFFLINE
tractormike
  • 166 Thanks
  • 1,488 posts
Posted June 14, 2010 - 05:56 AM
Nice work Daniel! That tractor will certainly be "as good as new " when you are done with it.
#13 DH1 ONLINE
DH1
    Electric Tractors
  • 5,231 Thanks
  • 5,546 posts
Posted June 20, 2010 - 03:12 PM
Interesting project looks like your making good progress, keep the pictures coming.
#14 Bolens 1000 ONLINE
  • 14,893 Thanks
  • 18,098 posts
Posted June 20, 2010 - 09:45 PM
Looks like you flew right past me!
Your definietly going to get it together before I can finish mine.
Great paint job by the way :dancingbanana:
#15 Bolens 1000 ONLINE
  • 14,893 Thanks
  • 18,098 posts
Posted June 21, 2010 - 04:46 PM
Got all the innards back in & engine back plate on. Then I hit a snag. I've found the mag/bearing plate is not the same between the S7D and the TR-10D....the one for the S7D is deeper, so bottomed on the crank. So I picked up the original plate & it was in 2 pieces. Was cracked & I hadn't seen it when I slipped it off. So if I feel up to it, I'll try TIG welding the plate back together. It'll still bolt up to the S7D block so I can bolt it down to get a good flush fit. After welding, I have to mount the mag over to the welded bearing plate. Been unbearably hot today, so worked on the engine some, & will get cows with newborn calves in late tonight when the temps drop a bit.
Yep, I have been there before. Everything is going smoothly and then something like that pops up.
I remember one time I assembled all the internal parts of the engine and got the gear cover all bolted on and I forgot to put in the ball that goes on the cam spring:wallbanging:
