Tires, Tires, Tires
12 replies to this topic
#1 js5020 ONLINE
js5020
  • 655 Thanks
  • 766 posts
Posted July 18, 2013 - 11:16 AM
Guys Im to the point with my WH project where I need to purchase tires. Having never purchased GT tires before I thought Id ask for reviews on a few brands, pricing is all over the board and I have no clue which brands are good, better, or run away.
I guess the best starting point is what the machine will spend its time doing, it is not going to be mowing lawn, it will be spending time pulling trailers, plowing/blowing snow, and pulling a moldboard or disk at the local plow days so Im thinking lug tires are in order for the back and tri ribs for the front, or is there a better option?
So whats your preference with the manufacturers,, Deestone, Carlisle, Firestone anyone head and shoulders above the rest?
#2 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted July 18, 2013 - 11:42 AM
Carlisle ags deestones are good rear and tri ribs would be good on front. I bought new turf tire for front of my jd 314 but wish I had tri ribs
larryd
#3 OldBuzzard ONLINE
OldBuzzard
  • 6,984 Thanks
  • 4,783 posts
Posted July 18, 2013 - 11:54 AM
What size tires?
With one of my Bolens Large Frames that uses 26x12-12 rears I put on a set of CST ANCLA tires.  They are a very aggressive 'lug' tire and quite a bit cheaper that the likes of Carlisle, etc.
I liked them so well that when I needed tires for my 'plowing tractor', I went with the same tires again, except I went with 26X11-12s.  The biggest reason was that they were/are on sale CHEAP, $74.99/tire. Being 1" narrower doesn't effect traction or flotation enough to matter.
http://www.discountu...IRES-UTV-TIRES/
For the fronts I went with 18x8.50-8 Vredestein 6 Ply V61 Heavy Duty 5-Rib tires from Miller tire.  Those actually cost as much as the rears, at $75.00/tire.  I went with the 6-plys for the weight carrying ability.  They do have them in 4-ply for $65.00.
http://www.millertir...hd-5-rib-6-ply/
Here's what they look like mounted on the tractor:
  • js5020 said thank you
#4 js5020 ONLINE
js5020
  • 655 Thanks
  • 766 posts
Posted July 18, 2013 - 12:26 PM
The tires I removed were 23x8.50x12 and 16x6.50x8,,, the manual says it should have had 23x9.50x12,,, the original owner must have downsized to save a few beans?
#5 OldBuzzard ONLINE
OldBuzzard
  • 6,984 Thanks
  • 4,783 posts
Posted July 18, 2013 - 12:34 PM
That might have been the case.  Of course the with a narrower tire you will get better traction, but less flotation.
At that size my setup won't be available.  The smallest Ancla tires I've listed have been 25x8-12 and 25x10-12 which would probably be too tall for fit  on your tractor
#6 Bolens 1000 ONLINE
  • 14,903 Thanks
  • 18,103 posts
Posted July 18, 2013 - 12:36 PM
What brand of tires and style of tread did your tractor originally have?
I'm not a big fan of the atv looking tires...
#7 js5020 ONLINE
js5020
  • 655 Thanks
  • 766 posts
Posted July 18, 2013 - 01:24 PM
It had turfs front and back, the rears were Goodyears, I think,, and the fronts were Kendas,, are the bar tires the answer here or would turfs and chains do better with the list of tasks,,, lets face it plowday is only two days of the year so realistically if turfs and chains would be a better all around choice Im up for that.
#8 OldBuzzard ONLINE
OldBuzzard
  • 6,984 Thanks
  • 4,783 posts
Posted July 18, 2013 - 01:40 PM
The Ags would be the best choice for what you to do, but for snow plowing/blowing you would need chains that are designed for Ags.  They are available but aren't cheap.
http://www.kenjones....23x10x12=
Edited by OldBuzzard, July 18, 2013 - 01:41 PM.
#9 Texas Deere and Horse OFFLINE
  • 14,730 Thanks
  • 15,470 posts
Posted July 18, 2013 - 01:58 PM
What year and model is your Wheel Horse? I can tell you what it came with from the factory.
#10 olcowhand ONLINE
  • 40,355 Thanks
  • 31,174 posts
Posted July 18, 2013 - 02:06 PM
Cheaper brands like Deestone, Nankang, Kenda, and other lesser known names have decent tires for sure, BUT, most all of them do NOT match the size they state on the tires.  For that reason, I stay with Carlisle or Titan myself, unless for a trailer queen that I won't actually work.  If you don't mind a "so called" 23x10.50/12 only measuring 22x9+/12, then Deestone is a fine tire, and quite a bit cheaper.
#11 js5020 ONLINE
js5020
  • 655 Thanks
  • 766 posts
Posted July 18, 2013 - 03:07 PM
These are for the 16 Auto I am bringing back to life in the WH forum,, should be a 1973.
#12 js5020 ONLINE
js5020
  • 655 Thanks
  • 766 posts
Posted July 18, 2013 - 03:10 PM
I had heard the diameter of some tires were not what they claimed,, this might be a problem for moldboard plowing, Im thinking the  loss of ground clearance is somthing not desired?
#13 JDBrian OFFLINE
  • 9,609 Thanks
  • 14,144 posts
Posted July 18, 2013 - 03:45 PM
If you go with AG's for the back and do any snow plowing or blowing on icy surfaces you will need chains as AG's are useless on ice. Worse than turfs. Turfs also tend to work better with chains due to their flat profile but a good set of 2 link chains works wonders with AG's. I had Carlisle Tru Power on the back of a JDx475 and they were OK for snow removal with the chains. That tire is not too aggressive for lawn mowing having smaller lugs at closer spacing than some other AG tires. Plowing a garden is a very special application for tires and AG's are going to be the best choice. The Carlisle All Trail is what JD offers as a tire choice on some of the new GT's .They are considered a very good all purpose tire but I don't think they would do well on plow day.
