Struck Md 45
mini dozer struck tiny little
15 replies to this topic
#1 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted July 17, 2013 - 09:24 PM
Hello i recently got a struck mini dozer all belt drive the older model and was wondering how i can hook the brinly or sleeve hitch up in the back its there but theres a linkage missing between the hitch and lever pictures would be great............. thanks
#2 MH81 OFFLINE
Posted July 17, 2013 - 09:36 PM
:welcome: to GTTalk.
I know little of the struck units, hope someone with more information comes along soon.
Good luck
#3 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted July 17, 2013 - 11:00 PM
Good luck
So they good machines i pretty new to them what can ya tell me about them i forgot i got all the manials for the thing so i might be able to find something in it
#4 superaben OFFLINE
superaben
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted July 18, 2013 - 06:16 AM
I can't help you with the questions, but you do have a nice looking Struck.   I've always wanted a little crawler like that.
Ben W.
#5 Ryan313 OFFLINE
  • 3,368 Thanks
  • 5,231 posts
Posted July 18, 2013 - 08:48 AM
I can't help with how the original lift went, but if you post a picture or two of where both the linkage would hook to the lever and hitch, we might be able to help you design another.
I look forward to seeing the progress you make with it!
#6 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted July 18, 2013 - 10:03 AM
Hello there and welcome :wave:
#7 Cvans ONLINE
  • 6,649 Thanks
  • 6,130 posts
Posted July 18, 2013 - 11:50 AM
Congratulations on your new purchase. Nice crawler
#8 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted July 18, 2013 - 12:31 PM
Yep where gonna go through iit this winter and redo the drive train but i shouldnt have a problem getting it done ill try and see if i can get some pictures of the close up or something
#9 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted July 18, 2013 - 03:09 PM
#10 MH81 OFFLINE
Posted July 18, 2013 - 05:04 PM
I spent an hour online looking for ONE good pic of the rear with lift.
It seems with the exception of superspeedex, struck photographers are among the worst for action and mechanical shots. ( I'm kidding, but only a Little... Not one pic did I find)
#11 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted July 19, 2013 - 08:38 PM
Well i found this in the original manual it looks as if i would need a whole new lower arm cause the timing is different for the plow mounts
#12 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted July 19, 2013 - 08:39 PM
couple more
#13 gopher OFFLINE
gopher
  • 763 Thanks
  • 757 posts
Posted July 19, 2013 - 09:56 PM
Is your cam just inside the tin work or further in side the body?
#14 gopher OFFLINE
gopher
  • 763 Thanks
  • 757 posts
Posted July 19, 2013 - 10:11 PM
Can't tell from your photo is there enough room on  the lift lever to bolt a split block to connect the lift rod to?
#15 MH81 OFFLINE
Posted July 20, 2013 - 08:13 AM
I was thinking the same thing. Add the second cam to the rod that's there.
With a set screw attachment, you'd have to have an indent for it to set in to keep it from slipping... May be better off to go ahead and weld it when you get the position right.
Another thought, instead of a cam on the horizontal shaft, maybe a clamp on "ear" on the vert piece? Be less apt to slip.
Also tagged with one or more of these keywords: mini dozer, struck, tiny, little
