Mower Deck Pulley Measurements
8 replies to this topic
#1 firstgen89sho OFFLINE
firstgen89sho
  • 82 Thanks
  • 90 posts
Posted July 16, 2013 - 11:14 PM
Looking for some measurements for both the 42" and 50" decks
Need the diameter of the upper pulley, and also the diameters of all 3 of the lower ones.
I have a mismash of pulleys here since the 50" was prev worked on by the prev owner, and I beleive that 42" stuff was used.
Thanks, Tom
Also if I have 3 of the same diameter for the lower pulleys, will that work fine, just as long as the upper one is proper for the deck size?
  • larryd said thank you
#2 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 11,270 Thanks
  • 6,077 posts
Posted July 16, 2013 - 11:47 PM
What would help us help you better would be to know what model tractor you are talking about and some other specifics..  Is it a Ford or Jacobsen?
#3 Lmiller3358 OFFLINE
Lmiller3358
  • 1,547 Thanks
  • 1,458 posts
Posted July 17, 2013 - 05:51 AM
Thanks, Tom
Is this a trick question ?
#4 KennyP OFFLINE
  • 40,973 Thanks
  • 47,143 posts
Posted July 17, 2013 - 06:14 AM
Tom, I may be able to get the mower drive pulley measurement for a 42" deck today. But It would take a bit more to get the cutter drive OD's as the deck is still on the tractor & I broke a rod on it. Mine is the 09JC9835 deck on my '77 LGT 165.
Not really! Looking at the parts list for these, they changed part #'s in '74 and at least 1 in '77, depending which model deck you have. For the 42" decks, there are 4 different model #'s and at least 3 different 50" deck models!
  • firstgen89sho, WNYTractorTinkerer and larryd have said thanks
#5 Rock farmer ONLINE
Rock farmer
  • 1,299 Thanks
  • 1,274 posts
Posted July 17, 2013 - 07:23 AM
My 50" top drive pulley is 5-3/4" for a 1/2" belt. The 42" deck uses a smaller pulley.
Joe
  • firstgen89sho and larryd have said thanks
#6 Rock farmer ONLINE
Rock farmer
  • 1,299 Thanks
  • 1,274 posts
Posted July 17, 2013 - 05:41 PM
It's kind of hard to see under my tractor. But, it's looks like the drive pulley on my 42" deck is 4-1/2" in diameter.
My 42" deck has aluminum spindle housings.
My 42" deck is model number 09JC-9835 serial number 13647.
The deck spindle pulleys on the 50" deck are 5" diameter.
My 50" deck has rectangular flat steel plates to mount the spindles.
My 50" deck is model number 09JC -983??? ( the tag is torn!).
I am looking for a drive pulley for my 42" deck. And the outer spindle pulleys for my 50" deck.
If you find some, please, let me know. I have seen missick's has the listed. But, at more than $50 a piece!
Thanks!
Joe
  • firstgen89sho said thank you
#7 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted July 22, 2013 - 07:26 PM
I have what I believe to be a 42" deck (measured from tip to tip on the blades). It has a 4-3/4" top pulley (actual OD). I can't find any numbers on it.
My impact gun is at work, so I won't be able to pop the pulley and cover off till tomorrow.
Tried a magnet on the spindle housings, definitely steel, has the square plates.
Maybe it is a 50", measures about 50" from deck edge to edge of chute.
Edited by Chopperhed, July 22, 2013 - 07:29 PM.
#8 firstgen89sho OFFLINE
firstgen89sho
  • 82 Thanks
  • 90 posts
Posted July 22, 2013 - 09:15 PM
That's a 42" deck. all you need to do is remove the 3 bolts, and then remove the bolts holding the cover on.
#9 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted July 22, 2013 - 11:35 PM
i'll let you do it on saturday, unless you need it before then
Edited by Chopperhed, July 22, 2013 - 11:39 PM.
