Copper Head Gaskets
12 replies to this topic
#1 wku88 OFFLINE
wku88
  • 23 Thanks
  • 38 posts
Posted July 16, 2013 - 11:00 PM
Anybody make copper head gaskets for Kohler K181? I've got a feeling I'm going to be going through a lot of the stockers.
  • larryd and JRJ have said thanks
#2 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,857 Thanks
  • 10,037 posts
Posted July 17, 2013 - 07:09 AM
I believe Midwest or one of those folks sell them in different thicknesses.
  • larryd said thank you
#3 boyscout862 OFFLINE
  • 13,430 Thanks
  • 9,380 posts
Posted July 17, 2013 - 08:23 AM
I don't think that a copper head gasket is soft enough to use with an aluminum Kohler head. I've had trouble before with Kohler heads. They had warped alittle. I filed them flat again, used a new Kohler head gasket, chased all threads and torqued them according to the manual. One head I was not able to reuse because the head gasket leak caused a notch to be burned into the head. When I get my shaper set up, I will resurface the head. Good Luck, Rick
#4 wku88 OFFLINE
wku88
  • 23 Thanks
  • 38 posts
Posted July 17, 2013 - 10:32 AM
Any contact info for Midwest? The head I have is relatively flat. It's the block I'm worried about. Had it in the machine shop to replace a valve seat, and told them to lightly surface the deck to make sure it was flat. It looks like they drug it around the parking lot! I tried to polish it out with 140 grit on my sander, but it still has some deep scratches. I guess I'll try the stocker first, but one of the reasons I tore it down in the first place is the stock gasket failed on the deck side. Looked like a worm ate through it.
#5 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted July 17, 2013 - 10:40 AM
You might need to do some more polishing
larryd
#6 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,857 Thanks
  • 10,037 posts
Posted July 17, 2013 - 11:31 AM
When I reuse a head gasket, I put aluminum paint on it.
http://midwestsuperc...WSC Catalog.pdf
The .031 copper gasket is $14.70. The .062 one is $21.00.
Edited by LilysDad, July 17, 2013 - 11:39 AM.
  • WNYTractorTinkerer and wku88 have said thanks
#7 wku88 OFFLINE
wku88
  • 23 Thanks
  • 38 posts
Posted July 17, 2013 - 12:29 PM
Thanks, Lilysdad. I was thinking of using some of the copper headgasket paste that they use on steel gaskets as well. The composite stock gasket really can't be reused successfully in my experience. Old steel sandwich Briggs gaskets on the other hand.... :D
#8 Utah Smitty OFFLINE
Utah Smitty
  • 1,705 Thanks
  • 1,789 posts
Posted July 17, 2013 - 12:52 PM
I've done the same on the steel sandwich gaskets, and it's worked fine as long as the gasket isn't deeply scratched, etc.
Smitty
#9 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 11,003 Thanks
  • 5,977 posts
Posted July 17, 2013 - 01:00 PM
What's up with the S-S-S-Snake-gaskets anyway?!?!?! :biting_nails:
This post brought to you by:   :spamani:    :bigrofl:  :bigrofl:  :bigrofl:
  • Dieselcubmike said thank you
#10 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,857 Thanks
  • 10,037 posts
Posted July 17, 2013 - 02:04 PM
Could you elaborate?
#11 MH81 OFFLINE
Posted July 20, 2013 - 09:22 AM
... Use COPPER HEAD gaskets...
:rolleyes:
  • boyscout862 and WNYTractorTinkerer have said thanks
#12 MH81 OFFLINE
Posted July 20, 2013 - 09:24 AM
I did some reading on the copper head gasket ideas. Almost everywhere you look, they say to anneal the gasket to make it more malleable.
#13 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 11,003 Thanks
  • 5,977 posts
Posted July 20, 2013 - 09:48 AM
My boat engine had copper head gaskets and I had to buy a can of a special sealer to use when I replaced a cracked block.. :wallbanging:   (I did a bad job of winterizing one year and paid dearly for it)  It still sits on the shelf in the shop & I look @ it every once in a while....   :(   That short block cost nearly 2K and that was back in 2006.. :anvil_drop:
