Ford/jake Replacement Steering Wheel Question
6 replies to this topic
#1 Firemang OFFLINE
Firemang
  • 184 Thanks
  • 195 posts
Posted July 16, 2013 - 09:47 PM
I was wondering if any of you fellas know if there's an aftermarket companies or another manufacturers steering wheel that will fit on a 72-76 (3310) Ford/Jake 145 steering column?  In the process of teardown for the tractor I'm refurbishing, the wheel was so rusted on I couldn't get it off the column.  A gear puller and tons of penetrating oil wouldn't even do it!   I had to cut the spokes and only then could I get the column out and put it in a 60 ton press to free it!   I had been lead bidder on a used one on Ebay but someone swooped in a the last second and outbid me by 50 cents, the criminal!   EverSharp in Ohio doesn't have any either.  Anyhow, if you guys had any ideas I'm all ears.  Thanks
  • larryd said thank you
#2 Rock farmer OFFLINE
Rock farmer
  • 1,217 Thanks
  • 1,243 posts
Posted July 16, 2013 - 10:05 PM
If you go to the top of the forum page, under sponsors, you will see hapco. Go to their website. They offer a reproduction John Deere 40 spline steering wheel for $60. I believe that will fit a Ross steering shaft. Which, is what I believe your tractor has. As always, trust but verify! I could be wrong!
Joe
#3 JDBrian OFFLINE
  • 9,628 Thanks
  • 14,152 posts
Posted July 17, 2013 - 06:30 AM
Also check with our sponsors for a good used wheel. I got one for a JD 317 from Joes last year. There were none on ebay.
#4 HALFSCALE OFFLINE
HALFSCALE
  • 504 Thanks
  • 533 posts
Posted July 17, 2013 - 08:51 AM
The two spoke "rubber" wheel, that some of jake/ford/oliver/white's had was also used on wheel horse.
#5 josh deaven OFFLINE
josh deaven
  • 479 Thanks
  • 574 posts
Posted July 19, 2013 - 08:24 PM
They also used a rubber 3 spoke wheel on the massey gts also would work.
#6 relic7680 OFFLINE
relic7680
  • 33 Thanks
  • 51 posts
Posted August 09, 2013 - 06:56 PM
Both the two and three spoke wheels can be sourced from other makes. There's also a guy on Ebay who rebuilds the columns.
#7 KennyP OFFLINE
  • 40,036 Thanks
  • 46,727 posts
Posted August 09, 2013 - 07:01 PM
That's an 'open' side tractor. Check with all our site sponsors as they may have what you need. Somebody else may have one and offer it to you!
