Time to Enter Tractor of the Month!
Sickle Adjustment, Walk Behind
3 replies to this topic
#1 Oakdale OFFLINE
Oakdale
  • 11 Thanks
  • 3 posts
Posted July 16, 2013 - 05:17 PM
Need a little advice:
I have a DB sickle mower. The pivot arm that comes off the wobble bearing and drives the actual sickle sections hits the side of the steel housing when it reaches full swing to one side. This is down near the bottom of the mower. The arm that carries the counter weight is what is hitting the side of the metal housing. I would like to reset it to move more in the middle of the space. Before I get out the BFH and go for it, can anyone tell me if there is (or isn't) any adjustment possible on this? Has this been banging into the housing since new? There is obvious evidence of the hammering, so it may have 'always' been this way. I'd sure like to correct it without cutting out clearance from the steel. There's gotta be a better way....
Thanks, All!
  • larryd said thank you
#2 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted July 16, 2013 - 08:32 PM
No help from me , need pics  but I'm sure someone can help
larryd
#3 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,023 Thanks
  • 3,172 posts
Posted July 17, 2013 - 02:43 AM
If you can post some pictures of this, it would help. I have been rebuilding one of these.
#4 Virginia Mike OFFLINE
Virginia Mike
  • 16 Thanks
  • 30 posts
Posted July 17, 2013 - 06:06 AM
Check the lower bearings that support the shaft. Wear may allow it to swing too far.
