Cub Cadet 147
19 replies to this topic
#16 powerstroker00 OFFLINE
powerstroker00
  • 669 Thanks
  • 332 posts
Posted August 07, 2013 - 11:54 PM
a lot of penetrating oil. let it soak for awhile, keep working at it, it will come off. just don't mess up your crank.
  • Rock farmer said thank you
#17 Rock farmer OFFLINE
Rock farmer
  • 1,197 Thanks
  • 1,232 posts
Posted August 14, 2013 - 06:53 PM
So, I finally got the drive pulley off! A couple of weeks of PB blaster, some heat - no go. So I supported the motor with a couple of bars under the pulley and hammered the crankshaft out of the pulley! Did not go easy. The crankshaft mushroomed about .010". I filed it down, and got it off. Now, on to the next issue. Re- bore or, just hone and rings? I need to do some more measuring. But, it's disassemble time either way!
Joe
#18 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted August 14, 2013 - 09:31 PM
Joe
If the piston was slopping, it's probably re-bore time.
#19 powerstroker00 OFFLINE
powerstroker00
  • 669 Thanks
  • 332 posts
Posted August 15, 2013 - 06:48 PM
Joe
I would re-bore. you've already got it apart.
#20 Rock farmer OFFLINE
Rock farmer
  • 1,197 Thanks
  • 1,232 posts
Posted September 01, 2013 - 05:57 PM
Finally pulled the piston. Compression ring disintegrated!
Bore did not get scored though!
The ring and piston pieces must have gone out the valves! I wonder if the guy driving it noticed anything? I can't imagine it ran after that.
Joe
