Ff 20 L H Axle Seal Failure
10 replies to this topic
#1 KennyP ONLINE
  • 32,186 Thanks
  • 42,011 posts
Posted July 16, 2013 - 08:31 AM
A while back, I changed out the RH seal and changed the fluid in the Peerless hydro, I noticed since moving that the LH was leaking. At that time, I looked at that side and all was fine, Since the new seal came yesterday, it was time to take it apart.
First off, 75# weight removal:
Then the tire:
Evidence of leakage:
Removing the 1-1/8" nut holding the flange on:
Cheater bar wasn't really needed. Now, the 3-jaw puller on the flange:
A good tightening and a couple love taps from the BFH persuaded it to comply:
On the left is the correct seal, Peerless 788049. The one on the right is what was in there, National 481782. Only half the sealing area with it.
Edit: I am using Wally World's Super Tech Heavy Duty Hydraulic & Transmission oil in this.
Now, I'm off to the local farm supply (Atwoods) to see if they have the flexible tubing for the fill hose & a stop at Dollar General for some degreaser. I am going to change the fluid again as there is still a lot of red fluid in there.
More to come, stay tuned!
  • olcowhand, MH81, Alc and 3 others have said thanks
#2 Arti ONLINE
Arti
  • 1,354 Thanks
  • 983 posts
Posted July 16, 2013 - 09:23 AM
Looks like a good start on the project.
  • KennyP and larryd have said thanks
#3 Bmerf OFFLINE
Bmerf
  • 1,763 Thanks
  • 1,464 posts
Posted July 16, 2013 - 09:54 AM
Quite a difference in the size of the seals. Good info. I'm glad that the flange was easy to remove. You should have this up and running in no time.
#4 JDBrian OFFLINE
  • 9,594 Thanks
Posted July 16, 2013 - 09:59 AM
Too bad someone put in the wrong seals. Now you have to do the job right. Is that flange keyed to the shaft? The ones on my 317 are splined. They came off easy as someone else had worked on the brakes recently.
#5 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted July 16, 2013 - 11:09 AM
Good project and glad you got correct seals
larryd
#6 olcowhand ONLINE
  • 37,194 Thanks
  • 30,208 posts
Posted July 16, 2013 - 11:30 AM
Sure wish the seals were in the outer end of the axle tube on my John Deere F935.  I had to completely remove the tube to put in new axle seals.  Same for many transaxles.
#7 boyscout862 ONLINE
  • 10,782 Thanks
  • 8,078 posts
Posted July 16, 2013 - 12:06 PM
Nice picture series. Is the axle worn where the seal contacts it? That is a rugged looking transaxle. I can see why you really like that tractor. Its as big and tough as my Bolens 1250. Good Luck, Rick
#8 UncleWillie ONLINE
  • 13,805 Thanks
  • 8,055 posts
Posted July 16, 2013 - 04:11 PM
Glad to see you are taking good care of my tractor till I come get it. :watching_you: :cowboy_shooter:
#9 KennyP ONLINE
  • 32,186 Thanks
  • 42,011 posts
Posted July 16, 2013 - 06:09 PM
Brian, the flange is keyed to the axle, but it is beveled.
Got it back together.
Here's the wheel after degreasing:
This is the axle shaft with a little anti-sieze applied:
All back together:
This is the new fill hose with new fluid:
Another back together pic:
This is what I drained out. Only about 10-12 hours on it:
Whole lot of red and dirty. I'll go some more and change the fluid and filter again.
#10 JDBrian OFFLINE
  • 9,594 Thanks
Posted July 16, 2013 - 07:42 PM
That fluid will act like a transmission flush. The new stuff should stay cleaner and closer to it's original colour. I find the red from auto transmission fluid is pretty persistent and takes more than 1 change to get it out of the system. The tractor looks Boss with those AG's on it!
#11 KennyP ONLINE
  • 32,186 Thanks
  • 42,011 posts
Posted July 16, 2013 - 08:02 PM
Thanks, Brian! I hope it stays more clear this go around. Seems to work smoother this time around. I did redo the 3-point lift rod again. I added a tube over the rod and only left about 1/4" 'float' this time around. That works out to about 1" float at the Box Blade, I think that is sufficient. I was tired of having to stop and wait for the lift to move 1/4-1/2" up when needed.
