Choke And Throttle Problem
19 replies to this topic
#1 trackcar OFFLINE
trackcar
  • 28 Thanks
  • 52 posts
Posted July 15, 2013 - 09:11 PM
I have a GT twin 18 h.p. that I can start with the choke allright, but if I add throttle and choke down the engine cuts off. The engine runs at 1/2 choke and 1/2 throttle, but not very well. It has been a few years since it ran respectably. The throttle cable is a little iffy behind the dash (coil wrap stretches a little), but still seems to function okay. The only gasket I have uncovered so far is the one between the air cleaner and the top of the carb and it is not in good shape. I will give an update tomorrow on other obsevations.
  • larryd said thank you
#2 MH81 OFFLINE
  • 29,979 Thanks
Posted July 15, 2013 - 09:14 PM
Which engine is in it? Also, can u see the choke plate operate correctly or is it only partly opening?
  • trackcar and larryd have said thanks
#3 HDWildBill OFFLINE
  • 8,984 Thanks
Posted July 15, 2013 - 09:31 PM
If the choke is functioning correctly then sounds like the Carburetor may be stopped up.
#4 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted July 16, 2013 - 04:13 AM
Give the engine a good once over/tune up and you'll probably find the problem. Sometimes a poor spark or no spark on 1 cylinder will cause problems like you are having.
  • HDWildBill, trackcar and larryd have said thanks
#5 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted July 16, 2013 - 11:34 AM
Sounds like the carb could a good cleaning and check fuel filter and lines also
larryd
  • HDWildBill, WNYTractorTinkerer and trackcar have said thanks
#6 olcowhand ONLINE
  • 42,900 Thanks
  • 31,942 posts
Posted July 16, 2013 - 11:39 AM
Likely has the Marvel Schreiber "DD" carb with built on fuel pump.  Likely needs a complete rebuild for entire carb plus the pump.  Doesn't take much crud to foul these carbs, and I'd bet you'll find all kinds of crud inside, especially inside the fuel pump..  If it has the composite float, best to get an all metal float too.   Myself, I'd go with a low pressure electric fuel pump, as these vacuum type can be a pain.
  • trackcar said thank you
#7 trackcar OFFLINE
trackcar
  • 28 Thanks
  • 52 posts
Posted July 16, 2013 - 08:22 PM
I can see the choke plate and it seems to be operating correctly.
Here is the engine info:
Craftsman 18HP
4 cycle   Electronic Ignition
Twin Cylinder  Cast-Iron Bores
On the top shield
Briggs & Stratton Co.
Model         Type          Code
422437    1209 01     88030112
It has a "pulse-type" fuel pump.
Trying to start it today after recharging the battery (I think I recharged it way too much lately), it wouldn't even turn over, not even when trying to jump it off my truck!  Just a high-pitched squealing sound. I was attempting to check spark plug "spark".
#8 MH81 OFFLINE
  • 29,979 Thanks
Posted July 16, 2013 - 08:26 PM
Twin Briggs huh? When you get it rolling over, do a compression test.
#9 olcowhand ONLINE
  • 42,900 Thanks
  • 31,942 posts
Posted July 16, 2013 - 08:32 PM
Never seen a GT with a Briggs!  Always been Onan.  Your carb isn't as finicky as the DD carbs.
#10 trackcar OFFLINE
trackcar
  • 28 Thanks
  • 52 posts
Posted July 17, 2013 - 11:31 AM
Whoa!  I'd have to take it to the shop for that one.
#11 WNYTractorTinkerer OFFLINE
WNYTractorTinkerer
    Tinker Master
  • 11,279 Thanks
  • 6,083 posts
Posted July 17, 2013 - 12:11 PM
Sounds like you need a trip to Sears or Harbor Freight to get a new toy (aka- compression tester!) :rocker2:
#12 trackcar OFFLINE
trackcar
  • 28 Thanks
  • 52 posts
Posted July 17, 2013 - 02:42 PM
I do have good spark on both cylinders. (Borrowed Deka from CC)
#13 MH81 OFFLINE
  • 29,979 Thanks
Posted July 17, 2013 - 03:49 PM
Might be time for a tool
 http://www.harborfre...ster-95187.html
#14 EricFromPa OFFLINE
EricFromPa
  • 4,199 Thanks
  • 3,368 posts
Posted July 17, 2013 - 04:17 PM
Sounds like your main jet is partly plugged up and the fuel pump is weak.
I just put a carb and fuel pump kit in my Craftsman II GT18 and a new starter gear on the starter.Sounds like your having the exact same problem that I was having.
The squealing sound is the starter trying to burn it's self up.Most likely your starter gear is partly stripped and jammed up on a gear.The pain in the butt thing is that it's darn near impossible to get the starter out without taking the engine out.
Mine did the exact same thing. I had to pull the engine to get the starter out.
I was cranking it pretty good trying to figure out why it wasn't starting.Started and ran awesome after rebuilding the carb and fuel pump.Then I was using it to haul my little wagon the other week and shut it off to load it up again left it sit for a couple hours and then I lost spark.So mine needs another coil to.
I haven't got to changing the coil yet or to put my starter back in but I got the starter back together with a new gear on it.I took the starter apart and cleaned it up and greased the bushings before I put the new gear on.
This is the Kit that I got.Complete with Fuel pump rebuild kit.
http://www.ebay.com/...76e7f40&vxp=mtr
Your starter gear should be a standard 16 tooth briggs starter gear.
Edited by EricFromPa, July 17, 2013 - 04:20 PM.
#15 TAHOE OFFLINE
TAHOE
  • 8,310 Thanks
  • 5,804 posts
Posted July 18, 2013 - 08:11 AM
I have a '88 or '89 Sears with Twin Briggs, did the same thing. It got to the point carb was so clogged wouldn't even hardly run with choke on. I bought rebuild kit for like $20-25 and she runs pretty well now.
  • EricFromPa and trackcar have said thanks
