Sears Ss16
21 replies to this topic
#16 dthomp17 ONLINE
dthomp17
  • 522 Thanks
  • 430 posts
Posted July 22, 2013 - 09:43 PM
I need a fuel tank for an SS16 I have--it came without one... I'm not trying to steal this sale from you, but what did you use for your homebuilt???
Smitty
Smitty, I tried my best to find a decent used tank at a reasonable price on ebay but all that I found cost at least $50 or more and most of them needed additional cleaning or some kind of repair.  Couldn't see spending that much money on a used tank and possibly end up with something that couldn't be repaired or that needed constant repair.
For my homebuilt, I used 1/16" thick diamond plate sheet aluminum only because that's what I had available.  Regular 1/16" aluminum sheet would probably work better.  I cut out the pieces, bent where needed with a sheet metal brake, and then put it all together with aluminum pop rivets and "alumiweld" that I bought at Harbor Freight.  Using "alumiweld" you can sorta weld aluminum with a map gas torch but it's tricky and takes a good bit of practice.  For the gas line connection, I drilled and tapped some 1/4" thick aluminum bar and "alumiwelded" to the bottom of the tank.  After assembly, I had to go back over some of the seams again to fix some small leaks.  I got most of the leaks fixed but I finally had to use some epoxy gas tank repair for one of them.  I've been using the tank now for about a year without any problems.  If there are any more leaks I haven't found them.  I've got a few pictures I took during the process if you're interested.
  • Utah Smitty said thank you
#17 Arti OFFLINE
Arti
  • 1,354 Thanks
  • 983 posts
Posted July 22, 2013 - 09:50 PM
Smitty
Gas tank on the Sears looks decent on the outside will check it tomorrow..
On the home built I used a tank out of a junk Ariens that was parted out a few years ago can't remember what model it was.
#18 Arti OFFLINE
Arti
  • 1,354 Thanks
  • 983 posts
Posted July 23, 2013 - 02:58 PM
Does it have a decent gas tank?  I've got a homemade one that's working OK but kinda looking for an original.
Smitty
Gas tank  looks in decent shape inside and out. Doesn't leak and is not bent up.  How about $10. Shipped to your door ?
#19 dthomp17 ONLINE
dthomp17
  • 522 Thanks
  • 430 posts
Posted July 23, 2013 - 06:40 PM
Arti, I sent you a PM regarding the gas tank including my shipping address.
#20 Utah Smitty OFFLINE
Utah Smitty
  • 1,655 Thanks
  • 1,758 posts
Posted July 23, 2013 - 10:44 PM
I'd like to see them--probably other members of GTT as well.  Why don't you start a new topic with it?
Thanks,
Smitty
#21 Golden Hurricane OFFLINE
Golden Hurricane
  • 16 Thanks
  • 24 posts
Posted August 04, 2013 - 10:49 PM
Utah Smitty, my '77 Roper/Sears GT needs a selector lever knob...I believe that the hole diameter is 3/8"...either red or black if you still have one of them. I know this is no big deal...just asking.
#22 TAHOE ONLINE
TAHOE
  • 7,182 Thanks
  • 5,279 posts
Posted August 19, 2013 - 11:32 AM
Arti, got my blades and on. Even though one was mis-matched, they all looked like they still had factory sharpening and tractor is cutting the best since I got it!
Thanks!!!
  • Arti said thank you
