Hyd Controls
4 replies to this topic
#1 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted July 15, 2013 - 02:34 PM
Can I convert my JD 314 to a h2 system for dual hyd on front or do I have go to a h3 system. I already have the h1 system to front and deck lift ?
larryd
  • 14,898 Thanks
  • 15,517 posts
Posted July 15, 2013 - 03:20 PM
Larry, you can do either, but if you want both remotes to be independent of the center rock shaft you need to go H-3
  • larryd said thank you
#3 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted July 15, 2013 - 04:56 PM
If you go H2 from a 317 you can get the valve and lines and they will bolt right on. You can easily make a lockout rod to lock out the rockshaft so it won't interfere with the blade angle. If you go with a H3 valve from a 400 series I'm not sure if it's that easy. You'd need custom lines made. I don't know if a 140 H3 valve would be a bolt on or not. Maybe, as the machines are very similar. Check with our site sponsors for parts.
  • Trav1s and larryd have said thanks
#4 Trav1s ONLINE
Trav1s
  • 3,644 Thanks
  • 4,600 posts
Posted July 15, 2013 - 07:05 PM
140 H3 valve would work but the lever assembly is very different.  Pretty sure the 140 stuff would bolt onto 300s and early 316K.  The later 316k I got h2 stuff from has the same type of levers as my '82 314.  317 parts are a direct fit.
#5 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted July 15, 2013 - 09:27 PM
Thanks guys . I guess it depends on what I find and price
larryd
