Lgt145 Stops Running
17 replies to this topic
#16 Jagman OFFLINE
Jagman
  • 25 Thanks
  • 46 posts
Posted August 03, 2013 - 07:22 AM
What causes engine surging? It seems to do that after I turn off the blades when the engine starts to die on me.
#17 boyscout862 ONLINE
  • 13,559 Thanks
  • 9,433 posts
Posted August 03, 2013 - 08:31 AM
Make sure the governor linkage isn't worn and the carb is adjusted correctly. Good Luck, Rick
#18 Jagman OFFLINE
Jagman
  • 25 Thanks
  • 46 posts
Posted August 06, 2013 - 04:32 PM
This weekend it's a new needle and seat because I thought it might be sticking closed intermittently. Also will be putting in a new float because the existing one has no tab to allow adjustment in the needle-open position (hanging down). I'll also give the governor linkage a close look, and reset the carb adjustments back to initial setup positions.
