Ariens S-14H Keep Dying When Engaging Pto
32 replies to this topic
#31 pvk OFFLINE
pvk
  • 4 Thanks
  • 20 posts
Posted July 21, 2013 - 09:07 PM
From the looks of the harness, I'd say that when the PTO engaged, it was killing the voltage level from the switch to the coil due to poor connections.  A new wiring harness, or you could just put individual spade connectors on, and a new switch, and you should be good to go.
I said my prayers today at mass, let the good lord shine down upon my tractor and I. I just tested continuity, and the ignition is complete junk. Update coming tomorrow. Thanks Howard!
Edited by pvk, July 21, 2013 - 09:07 PM.
#32 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted July 22, 2013 - 04:32 AM
Looks like you've found a problem, hopefully the only one. That connector is toast. I've seen this happen often. If you can't find another connector you could replace the connector with separate crimp on male and female pin connectors. You'd need to label or color code the wires and document the changes in your manual. Check all your connectors and clean them just to be sure you don't have more bad connections.
#33 pvk OFFLINE
pvk
  • 4 Thanks
  • 20 posts
Posted July 25, 2013 - 11:45 PM
Update...sort of.
I ordered the new ignition switch off amazon and I installed it yesterday via spade connectors. The tractor starts up again. But when I engage the pto, the tractor keep running now, it doesn't even recognize I pulled the pto switch out/engaged it.
I am going to run down to tractor supply/auto parts store and grab an on/off switch and wire it to the pto. PTO switch might be the bad also now?  I don't know, i'm just frustrated!
How should I wire this up to the pto
If anyone has an other guidance on what else if left to do, it would be greatly appreciated!
