New Member, Need 59 Suburban Info
44 replies to this topic
#31 MH81 OFFLINE
Posted July 16, 2013 - 06:15 PM
By the way, member stripmine has an owners manual for that tractor on his site. He uploaded it in three parts.
http://www.stripmine...b/db_burb_1.pdf
http://www.stripmine...b/db_burb_2.pdf
http://www.stripmine...b/db_burb_3.pdf
#32 ryan_schlotz OFFLINE
ryan_schlotz
  • 20 Thanks
  • 32 posts
Posted July 16, 2013 - 06:17 PM
The last three numbers of the model number is 601 and I know its a pull start, lol. Anyway I can get that bushing/bearing for the pull start , mine squeals and doent engage sometimes.
#33 MH81 OFFLINE
Posted July 16, 2013 - 06:44 PM
The piece behind the pull start unscrews off the end of the crank. I don't remember if RH thread or left tho...
You're as far ahead to take the piece to your local small engine repair shop and see if they have one. If not, take the 2 little bolts out and be careful not to drop the little balls. Clean it all up and spray with a light (like blaster) oil. Just enough to slow the rust.
Then you will need to lube the square part on the shaft. I'm not explaining it well, but you'll see when it's apart.
  • ryan_schlotz said thank you
#34 ryan_schlotz OFFLINE
ryan_schlotz
  • 20 Thanks
  • 32 posts
Posted July 16, 2013 - 06:47 PM
Well im going to attempt to work on the carb wish me luck...r repair kits for this carb style easy to get ur hands on and expensive?
#35 MH81 OFFLINE
Posted July 16, 2013 - 09:40 PM
I would contact one of the site sponsors regarding kits. One of them will have access to them.
#36 ryan_schlotz OFFLINE
ryan_schlotz
  • 20 Thanks
  • 32 posts
Posted July 16, 2013 - 10:14 PM
Either I should or send the engine off to be rebuilt because engine is consuming a lot of oil. Hoping its just rings, I would hatento hear bad news like cylinder wall damage.
#37 MH81 OFFLINE
Posted July 17, 2013 - 06:55 AM
If you have a carb issue, it can run gas into the oil, thinning it. Then you have a lot of oil in there that's thin and will blow past the rings easy. Also more possibility for damage.
Make sure the oil isn't gas laced.
Do you have a small engine shop nearby?
#38 ryan_schlotz OFFLINE
ryan_schlotz
  • 20 Thanks
  • 32 posts
Posted July 17, 2013 - 11:23 AM
Ill check the oil and yeah I have a few in my town and some near by towns. How do I find a rebuild manual for this engine?
#39 ryan_schlotz OFFLINE
ryan_schlotz
  • 20 Thanks
  • 32 posts
Posted July 17, 2013 - 01:50 PM
Does anyone know the horsepower rating for a b&s model 9? I believe its a 1956 year. Thinking about doing a engine swap until I can rebuild the original 14 engine.
#40 MH81 OFFLINE
Posted July 17, 2013 - 06:17 PM
I found a listing showing a 2.25 bore by 2.00 stroke. General rule of thumb ive been told. 1cu in is approx equal to 1 hp... so, convert that cyl to cu in. And get 7.95
I also found a list of conversions. It said that engine tuning, compression, detuning and any manner of influences can change the conversion drastically, but that 16 cc is approx equal to 1 HP
So convert the cyl displacement to cc and divide by 16... 8.125
I'm sure it's not spot on... But "around" 8hp? Same formulas on the 14 show "around" 11.
Anyone have a reference that says?
#41 MH81 OFFLINE
Posted July 17, 2013 - 06:33 PM
I was weeding and thought "that can't be right"
The model 19 that is in my 725 is a 7.25 hp engine.
It has a bigger bore listed than the 14.
Never mind everything I've posted in the last hour... Heat must be getting to me :D
#42 ryan_schlotz OFFLINE
ryan_schlotz
  • 20 Thanks
  • 32 posts
Posted July 17, 2013 - 08:25 PM
I feel ya, after it rained here today it got humid and over 90 ive been outside messing with both carbs on the # 9 and 14 both still arent running right, #9 has fuel pouring out of carb. Im out of ideas. Someone please help, tell me what am I doing wrong????
Ive took both apart and put back together but still no beuno..... I can get the #9 running off of starter fluid and I know I have spark, just cant get the carb figured out....I NEED CARB HELP!!! Any help would be muchly appreciated
#43 MH81 OFFLINE
Posted July 17, 2013 - 08:42 PM
Is this the carb you have?
If not, please post a pic of it.
#44 ryan_schlotz OFFLINE
ryan_schlotz
  • 20 Thanks
  • 32 posts
Posted July 17, 2013 - 08:57 PM
Yeah thats my carb, I need that exact rebuild kit, where do I get one that doesnt break the bank? My carb on the suburban is exactly the same as that one in the video. My # 9 engine is the same except it has 4 bolts instead of 3
#45 MH81 OFFLINE
Posted July 17, 2013 - 09:08 PM
If it were me, I'd send the site sponsors each a PM or post in their forums. I'm sure one of them has rebuild kits for them.
