My Sawmill
36 replies to this topic
#1 mikes47jeep OFFLINE
mikes47jeep
  • 60 Thanks
  • 22 posts
Posted July 14, 2013 - 08:59 PM
hi all
one of my many other projects is restoring a 1928 Ireland No. 2 sawmill
i got it in Feb 2012
it was pretty much a basket case
now its almost 100% rebuilt, and i hope to be cutting before 2013 is over
  • DougT, OldBuzzard, Alc and 12 others have said thanks
#2 UncleWillie OFFLINE
  • 16501 Thanks
  • 9061 posts
Posted July 14, 2013 - 09:00 PM
Looks like a big undertaking. Can't wait to see it slicing wood.
  • hamman and mikes47jeep have said thanks
#3 Short_Circuit OFFLINE
Short_Circuit
  • 72 Thanks
  • 67 posts
Posted July 14, 2013 - 09:03 PM
I will be watching this build!  Looks like a cool project :watch_over_fence:
#4 Team_Green OFFLINE
Team_Green
  • 2214 Thanks
  • 2305 posts
Posted July 14, 2013 - 09:18 PM
Sweet project.. Im looking forward to more pics of this unit..
#5 JD DANNELS OFFLINE
JD DANNELS
  • 3791 Thanks
  • 3907 posts
Posted July 14, 2013 - 09:20 PM
Wow that is quite a project. You pretty much need a sawmill to build a saw mill?
  • hamman and oldedeeres have said thanks
#6 Sawdust OFFLINE
Sawdust
  • 6798 Thanks
  • 3799 posts
Posted July 14, 2013 - 09:56 PM
I will definitely be watching this...I can smell the sawdust now. That isn't you behind the gloves in pic three is it.
#7 CRFarnsworth OFFLINE
CRFarnsworth
  • 5540 Thanks
  • 2384 posts
Posted July 14, 2013 - 10:05 PM
That PROJECT looks more like a JOB.   Good luck on the restoration.  If you run out of timber to cut come see me.  :D  Rick
#8 Dieselcubmike OFFLINE
Dieselcubmike
  • 1345 Thanks
  • 1529 posts
Posted July 14, 2013 - 10:14 PM
Looks great mike. Never really seen one of those before :thumbs:
#9 superaben OFFLINE
superaben
    Con Man
  • 7672 Thanks
  • 5677 posts
Posted July 15, 2013 - 06:25 AM
There's nothing better than loading an engine running a sawmill, and smelling that exhaust and sawdust.
Do we all get to come over and play lumberjack with you for a day?
Ben W.
#10 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 18672 Thanks
  • 11811 posts
Posted July 15, 2013 - 06:39 AM
What kind of shape are the bearings in?
#11 HDWildBill OFFLINE
  • 8994 Thanks
  • 8664 posts
Posted July 15, 2013 - 08:55 AM
Quite an interesting project.  Looking forward to see it when it is done.
#12 powerking56 OFFLINE
powerking56
    Collector of stuff
  • 909 Thanks
  • 1805 posts
Posted July 15, 2013 - 10:59 AM
Wow, what a project, but glad to see someone saving old equipment like that.  What are you planning to power it with?
#13 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2029 Thanks
  • 3172 posts
Posted July 15, 2013 - 11:03 AM
If it were me, I'd find an old steam engine to power it. With all the slab wood left over, it would be cheap to run.
#14 mikes47jeep OFFLINE
mikes47jeep
  • 60 Thanks
  • 22 posts
Posted July 17, 2013 - 05:45 PM
HA HA no that's not me, they were there so the blades wouldn't cut through the straps on the ride home
Funny you should ask that, the new main bearings just came in $425 from Timken
the plan is to get an older gas or diesel power unit, a friend just told me about a bunch of chippers that a tree trimming company just dumped at a local scrap yard, ill see if i can score an engine with a rockford PTO for cheap
Edited by mikes47jeep, July 17, 2013 - 05:46 PM.
  • powerking56 and Sawdust have said thanks
#15 mikes47jeep OFFLINE
mikes47jeep
  • 60 Thanks
  • 22 posts
Posted July 21, 2013 - 02:39 PM
the next step was getting the cast iron pulleys off without destroying them.
i tried the heat, soak, beat, repeat method for about a week, no go
i ended up making a large puller and over the span of about 3 hours today i managed to get the pulleys off the shaft
now i can polish it up, and replace the inner bearing, and start re-assembly
  • IamSherwood, HDWildBill, twostep and 2 others have said thanks
