F 50501 Sno Caster Help Needed! Versa Matic Or Ride A Matic
16 replies to this topic
#1 antiquetractors OFFLINE
antiquetractors
  • 327 Thanks
  • 521 posts
Posted July 14, 2013 - 01:09 PM
I just got a f50501 sno caster for my ride a matic, these are also used on the versa matics. I am in need of the pulleys. Does anyone have the dimensions or a clear picture of how the pulley set up is on the blower so I can make this functional again.
Thanks
#2 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted July 14, 2013 - 07:55 PM
I have a couple snow casters here but dont know what models they are off the top of my head.
If I remember I'll go check tomorrow
  • antiquetractors said thank you
#3 antiquetractors OFFLINE
antiquetractors
  • 327 Thanks
  • 521 posts
Posted July 14, 2013 - 08:08 PM
That would be great!
Here is the blower
  • Bolens 1000 said thank you
#4 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted July 14, 2013 - 08:30 PM
Here is the blower
I think I got the same one
Here's a pic of when I picked it up a few years ago.
Hopefully its not too hard to get at in the shed.....
  • Bruce Dorsi and antiquetractors have said thanks
#5 Bruce Dorsi ONLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 5127 Thanks
  • 2912 posts
Posted July 15, 2013 - 03:58 AM
Is that the decal you are looking for?
#6 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted July 15, 2013 - 07:51 AM
no, This one is newer
#7 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted July 16, 2013 - 08:57 PM
I have not forgotten about the measurements.... Will try and get them tomorrow hopefully
#8 antiquetractors OFFLINE
antiquetractors
  • 327 Thanks
  • 521 posts
Posted July 17, 2013 - 12:09 AM
Thanks. Hopefully I can get the right pulley's
#9 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted July 17, 2013 - 03:49 PM
Ok here we go:
Cast iron Pulley
6.5'' OD
9/16'' Hub on one end the other is flush with the pulley.
Width of the groove is 9/16'' (For a 1/2'' Belt)
Idler:
3'' OD
1'' Width
#10 antiquetractors OFFLINE
antiquetractors
  • 327 Thanks
  • 521 posts
Posted July 17, 2013 - 04:12 PM
Ok here we go:
Cast iron Pulley
6.5'' OD
Idler:
3'' OD
1'' Width
Thank you very much!!
The blower is being shipped to me so I don't have it yet. How is the idler attached? Does it have an arm that goes off the drive pulley to support it?
#11 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted July 17, 2013 - 04:17 PM
Hard to tell from the pics but are you missing the idler arm as well?
#12 antiquetractors OFFLINE
antiquetractors
  • 327 Thanks
  • 521 posts
Posted July 17, 2013 - 04:27 PM
I think it is there. I'm not 100% sure. Here are some closer pics that you might be able to have a better idea.
#13 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted July 17, 2013 - 08:52 PM
Looks like the arm is there.
They used a bushing and grease fitting on the idler similar to the power-Ho's Idler.
They probably only have sealed idlers now in stores so you may have to go with that.
#14 antiquetractors OFFLINE
antiquetractors
  • 327 Thanks
  • 521 posts
Posted July 18, 2013 - 12:43 PM
Thanks. I will have to do some searching and see what I can find. Tractor supply probably has the pulleys I need. There aren't many places around here that keep those parts in stock.
#15 antiquetractors OFFLINE
antiquetractors
  • 327 Thanks
  • 521 posts
Posted July 24, 2013 - 11:24 AM
Did some searching and found a NOS idler pulley. I have to figure out what size bearing it needs but I think it will work.
