John Deere 314 Pto Clutch Removal
3 replies to this topic
#1 jdslednut OFFLINE
jdslednut
  • 680 Thanks
  • 851 posts
Posted July 14, 2013 - 12:40 AM
Looking for some ideas on the process to remove the pto clutch from my 314. Is it supposed to just slide off after removing the crank bolt or are there others holding it on? It's a slimy mess there and I haven't done any gunk scraping yet. I just don't want to tear things depart I don't have to as it worked fine and I would rather not have to make a bunch if adjustments to reinstall. Does it slide off as a unit? Puller necessary?
  • JRJ said thank you
#2 jd.rasentrac ONLINE
jd.rasentrac
  • 4,799 Thanks
  • 4,294 posts
Posted July 14, 2013 - 02:17 AM
send u a pm - maybe the pics can help. but I fear, they don't.
  • jdslednut said thank you
#3 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted July 14, 2013 - 06:44 AM
This should help
#4 rowder OFFLINE
rowder
  • 6 Thanks
  • 15 posts
Posted July 14, 2013 - 01:07 PM
hi , I have a 285 john deere , and once you take the crank bolt out it just slides off , but when you put it back on make sure you have the bolt tight
