Backups.
25 replies to this topic
#16 olcowhand ONLINE
  • 41,276 Thanks
  • 31,449 posts
Posted July 14, 2013 - 03:55 PM
The only Raid I understand is a can of bug spray!  :rolling:
#17 HDWildBill OFFLINE
  • 8,975 Thanks
Posted July 14, 2013 - 04:18 PM
That's why I put the link to explain a RAID. :smilewink:
#18 HDWildBill OFFLINE
  • 8,975 Thanks
Posted July 14, 2013 - 04:20 PM
Any of you Mac guys know if the OS X has the RSync funtion?  This is also a good way to do backups.  You can write a script and then set it to run in the cron and it will sync up the two Folders.
#19 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted July 14, 2013 - 04:26 PM
Yep
rsync  version 2.6.9  protocol version 29
Copyright © 1996-2006 by Andrew Tridgell, Wayne Davison, and others.
It has cron but permission denied, I would need root access.
cron: can't open or create /var/run/cron.pid: Permission denied
Edited by Amigatec, July 14, 2013 - 04:31 PM.
  • HDWildBill said thank you
#20 HDWildBill OFFLINE
  • 8,975 Thanks
Posted July 14, 2013 - 04:42 PM
Yep
Yes you do have to run it as root.  There is a program in Linux called "Luckybackup"  Which gives you a graphical interface to use and then writes the script for you.  You can even schedule the cron with in the program.
#21 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted July 14, 2013 - 04:45 PM
It been a few years since I have edited cron. I would have to write the script, store it probably in /var/etc/script, and then edit cron to tell it when to run it.
It would probably be easier to do a crontab.
Edited by Amigatec, July 14, 2013 - 04:47 PM.
#22 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted July 14, 2013 - 04:51 PM
Man this is making my head hurt, I would have brush up on vi, cron, and bash all at the same time. LOL
#23 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted July 14, 2013 - 05:00 PM
There was an Linux editor I used all the time called Midnight Commander, mc for short. It was the same thing as Norton Commander for MSDOS.
#24 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted July 14, 2013 - 06:04 PM
Remember this?
#!/bin/bash
The bash shebang!
#25 HDWildBill OFFLINE
  • 8,975 Thanks
Posted July 15, 2013 - 09:19 AM
MC is still available in most Disto's.  There was a windows version of MC at one time but I think when M$ switched over from the DOS kernel to the NT Kernel they quit supporting Windows.
Still use the bash on this side of the house. Although these days I tend to go with more the graphic side instead of the command line.  It is getting harder to remember the commands and their options.
#26 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted July 15, 2013 - 11:00 AM
MC will help you write bash scripts as well.
