Did A Little Box Blading Tonight
does anyone know anything ab
17 replies to this topic
#16 Chopperhed OFFLINE
Chopperhed
  • 1,852 Thanks
  • 1,071 posts
Posted July 12, 2013 - 07:28 PM
Thanks Tom!
That Jake has got me stumped. I fixed a bunch of things on it. It smoked a little on start up when I got it. But, after a few seconds it ran clean. Now that I've fixed it so it runs good, it smokes bad! I'm getting gas in the oil. I've got it narrowed do to; bad carburetor, bad fuel pump or, bad rings! Can't believe I need to do a ring job on it! And it has an oil leak up under the covers near the oil fill tube. I'm thinking maybe the tube itself has a hole in it. I may tear it all apart this weekend!
Joe
If you have gas in your oil, your carb needs a good clean/rebuild. Probably float needle and seat problem
  • Rock farmer said thank you
#17 Rock farmer OFFLINE
Rock farmer
  • 1,197 Thanks
  • 1,232 posts
Posted July 13, 2013 - 06:43 PM
I replaced the float needle. Could not remove the seat because I would need a thin wall socket to do that! Does anyone know where I can buy a thin wall socket? I'm really not set up to grind one down myself!
The engine will idle down to a slow speed now. So, I don't think it's pouring gas into the combustion chamber?
I was thinking maybe the pump was leaking directly into the crank case?
Thanks!
Joe
#18 HowardsMF155 ONLINE
  • 2,841 Thanks
  • 2,979 posts
Posted July 13, 2013 - 07:08 PM
If it is a Kohler, then yes, the fuel pump may be leaking into the crankcase.
