Any One Know Where To Get Ss14\ss15 Tie Rod With Ends
11 replies to this topic
#1 searspullingtractor OFFLINE
searspullingtractor
  • 34 Thanks
  • 103 posts
Posted July 11, 2013 - 01:30 PM
sears does not have them
#2 boyscout862 OFFLINE
  • 13,559 Thanks
  • 9,433 posts
Posted July 11, 2013 - 02:04 PM
It would help to see what they look like. The tie rod ends on most GTs are off the shelf. Try Bailey Sales for generic parts. Good Luck, Rick
#3 TAHOE OFFLINE
TAHOE
  • 8,310 Thanks
  • 5,804 posts
Posted July 11, 2013 - 02:10 PM
Try McMaster Carr.
Here are parts numbers from another guy who upgraded the ones on his custom. He had 1/2"  tie rods, but ended up having to drill out the steering arms to accept the  larger end bolt and he had to grind just a tad off the two center ones as they rubbed. You will also need nuts for them.
These are greasable also. They may have smaller sizes, jsut have to know what sizes you have on your tractor.
Sometimes I've found them at Tractor Suppy and Rural King.
Edited by TAHOE, July 11, 2013 - 02:12 PM.
#4 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted July 11, 2013 - 04:09 PM
You should be able to source them elsewhere. Sometimes the tie rods have 1 LH thread end so watch out for that. The LH thread ones are harder to find.
#5 KC9KAS OFFLINE
KC9KAS
  • 5,469 Thanks
  • 4,725 posts
Posted July 11, 2013 - 04:27 PM
McMaster-Carr has left hand threaded ends as well as left hand threaded rod, so if you can't make it from McMaster Carr parts, you can't make it at all!
#6 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted July 11, 2013 - 04:53 PM
The ends are available in the link below if >> you are looking for 7204H which is now 7444R or 109851X from AYP and is left handed, good luck :thumbs:
P.S. You might have to call them for right side #
http://www.hyperpart...ref~1001~1003~1
#7 searspullingtractor OFFLINE
searspullingtractor
  • 34 Thanks
  • 103 posts
Posted July 11, 2013 - 10:28 PM
thanks I am looking for a cheap kit
#8 searspullingtractor OFFLINE
searspullingtractor
  • 34 Thanks
  • 103 posts
Posted July 11, 2013 - 10:31 PM
can you put ss12 tie rods on the ss14
Edited by searspullingtractor, July 11, 2013 - 10:32 PM.
#9 searspullingtractor OFFLINE
searspullingtractor
  • 34 Thanks
  • 103 posts
Posted July 11, 2013 - 10:35 PM
I need the ends and the rod
#10 Dane in PA OFFLINE
Dane in PA
    Permanent Lurker
  • 552 Thanks
  • 616 posts
Posted July 11, 2013 - 10:55 PM
Yes, the steering set-up is the same throughout all of the models of Roper made Suburbans.
#11 Dane in PA OFFLINE
Dane in PA
    Permanent Lurker
  • 552 Thanks
  • 616 posts
Posted July 11, 2013 - 10:56 PM
Most hardware stores will sell the tie-rod ends.  Then you can just thread a rod, cut at the desired length, to fit your tractor.
#12 MH81 OFFLINE
  • 29,979 Thanks
Posted July 11, 2013 - 11:24 PM
I merged all three threads into one.
Please pardon the inconsistency of flow, but threads merge based on time stamp, not in order of response to original posts.
