Rebuild 50" Mtd 190-992A
731-0335 roller
6 replies to this topic
#1 Kentrails OFFLINE
Kentrails
  • 13 Thanks
  • 52 posts
Posted July 11, 2013 - 01:17 PM
I have been hesitating spending $39 (+- shipping) each for these rollers, Does anyone have a connection for a screaming deal, as opposed to screaming about the deal? I also need a 117" V-Belt.
While rebuilding the Right angle gear box I found that Peerless is now owned by Husky and some part #s have changed. The part no. for the gear box is on a tab under the pully. I had to take the pully and shaft to a shop that had a press to seperate them, cuz I have no press.DSCF0059.JPG DSCF0061.JPG DSCF0063.JPG DSCF0070.JPG DSCF0078.JPG
Upon investigation I see that thr numbers are the same,except for the "PE" prefix, the part number for the gear box was different than my manual, also the seals are different. I will post more data when my notes are found
PN: 780034 is an R14 open bearing; (although I have been told I could have used a sealed bearing and peeled the plastic seal off)
PN:788031 is - http://www.skf.com/g...3&imperial=true
PN: 788029 is - http://www.skf.com/g...&imperial=false
Attached File  Parts Manager Pro.pdf   159.01KB   61 downloads
Edited by Kentrails, July 12, 2013 - 11:17 AM.
#2 achomesteader OFFLINE
achomesteader
    GT Fanatic
  • 867 Thanks
  • 2,231 posts
Posted July 12, 2013 - 04:39 AM
Maybe not a screaming deal, but...
http://search.cartse...731-0335&go=GO!
#3 KennyP ONLINE
  • 40,989 Thanks
  • 47,156 posts
Posted July 12, 2013 - 05:26 AM
I got boat trailer rollers for the Ford's deck!
  • Alc, motobreeder and Arti have said thanks
#4 Kentrails OFFLINE
Kentrails
  • 13 Thanks
  • 52 posts
Posted July 12, 2013 - 11:14 AM
Shipping seems to be extreme with that site.
I found that this one does not charge shipping: http://www.mowpart.c...oller-deck.html
#5 VTXrider OFFLINE
VTXrider
  • 545 Thanks
  • 396 posts
Posted July 12, 2013 - 07:39 PM
I always had problems with these rollers seizing and bending the roller shaft. I drove the spring pins out of the ends of the shaft to separate it from the height adjusters. I then welded and L-shaped bracket to each adjuster, right hand, left hand. A 5" replaceable hard caster wheel is then bolted to the adjuster. The rear of the deck now behaves better on uneven turf.
Edited by VTXrider, July 12, 2013 - 07:42 PM.
  • Alc and Kentrails have said thanks
#6 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,452 Thanks
  • 5,621 posts
Posted September 28, 2014 - 06:31 PM
Do you have any pictures of your wheel setup?
#7 VTXrider OFFLINE
VTXrider
  • 545 Thanks
  • 396 posts
Posted September 29, 2014 - 07:37 AM
I do.
Edited by VTXrider, September 29, 2014 - 07:39 AM.
  • DH1 and Sawdust have said thanks
