Electronic Ignition
8 replies to this topic
#1 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 13,323 Thanks
  • 9,788 posts
Posted July 11, 2013 - 11:43 AM
There are various manufacturers that produce EI kits for some engines including motorcycle engines.
Does anyone make one for the Kohler K engine?
  • larryd and JRJ have said thanks
#2 Trav1s OFFLINE
Trav1s
  • 3,310 Thanks
  • 4,365 posts
Posted July 11, 2013 - 11:49 AM
www.kirkengines.com has two available.  One eleminates condensor and the other is a photo-electric piece that eliminates the points and condensor.  I have the later on my 120 and hope to give a good review once I get the carb replaced.
  • LilysDad and larryd have said thanks
#3 TAHOE OFFLINE
TAHOE
  • 7,978 Thanks
  • 5,676 posts
Posted July 11, 2013 - 02:23 PM
Here is one some of the pullers use on their tractors bought through midwest super cub, I actually modified the trigger and run on my Tecumseh OH160 in my sears. My buddy runs these on their modified Kohler pulling motors. Comes with magnetic ring that mounts on crank and then feeds a 3 Ohm coil ( Bosch blue coil). The whole system is the ring, the trigger and a coil. My tecumseh runs really well with it.
http://www.mcssl.com...igger-ignition-
  • Alc, sacsr and LilysDad have said thanks
#4 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 13,323 Thanks
  • 9,788 posts
Posted July 11, 2013 - 03:46 PM
Thanks to both of you. I was familiar with the point saver, but not the photo-electric. Kirk makes a lot of good stuff.
#5 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 13,323 Thanks
  • 9,788 posts
Posted July 11, 2013 - 09:05 PM
I  emailed Kirk about the "PointSlayer" because it wasn't on his website. He said he no longer offers it.
#6 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 13,323 Thanks
  • 9,788 posts
Posted July 11, 2013 - 09:07 PM
does this mount behind the pto pulley?
#7 TAHOE OFFLINE
TAHOE
  • 7,978 Thanks
  • 5,676 posts
Posted July 12, 2013 - 09:15 AM
I am not sure, I think their magnetic ring mounts behind the flywheel on the crank shaft somehow. I did not use their ring on my Tecumseh, I glued a magnet where the pins are in the Tec flywheel, then made my own trigger mount to get it to work.
I would suggest emailing Midwest and asking them. I know my buddy and his family used them on their pullers, they have some super modded Kohlers and they work great on them, but I haven't seen one mounted in person, my buddy made the setup for my Tecumseh.
  • LilysDad said thank you
#8 Trav1s OFFLINE
Trav1s
  • 3,310 Thanks
  • 4,365 posts
Posted July 16, 2013 - 08:18 PM
I have finally resolved all the problems with my 120.  Between the Kohler 26 carb in place of the Walbro (get behind me Satan!) and the Pointslayer the 120 is an entirely different machine.  It starts right off and sounds smoother.  I am sold on the Pointslayer on any Kohler-powered machine that I own.  It is easy to install, tune, and maintain.  Here is a vid of the 120 after the carb tweak and Pointslayer install.
The idle is a bit low in this one:
th_E6A5CEE8-BCA9-424B-BB41-D571BB3F55D9-
This one is better:
th_FBF0CE42-28DA-474F-89D8-9487DE205D3E-
#9 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 13,323 Thanks
  • 9,788 posts
Posted July 17, 2013 - 07:15 AM
Figures! Find something good and they discontinue it. Kirk said that the manufacturer of one component of it stopped making that part.
