Panzer T70E (Electric) Build Log
65 replies to this topic
#46 BowDown ONLINE
BowDown
  • 551 Thanks
  • 562 posts
Posted January 30, 2014 - 03:42 PM
Moving forward! I purchased a front axle assembly from a Bolens 1050! Got it for $50 picked up. :)
Nice thing about this is the PTO shaft unit I have will bolt up to this, it will also give me the proper tab mounts for Bolens front attachments, and gives me clear direction to go with the steering system. I'm going to start making the adapter for the electric motor to transmission, then it's a matter of cutting and mocking things up!
$(KGrHqV,!nUFIjc9u2vwBSPskwe2fw~~60_57.J
#47 cookiemonster OFFLINE
cookiemonster
  • 409 Thanks
  • 1,274 posts
Posted February 02, 2014 - 09:45 PM
Can't wait to see it.
#48 BowDown ONLINE
BowDown
  • 551 Thanks
  • 562 posts
Posted February 03, 2014 - 09:56 AM
Part is now in my possession. Very happy with the condition!
Posted from my Samsung Galaxy S III 32gb via tapatalk 2.
#49 BowDown ONLINE
BowDown
  • 551 Thanks
  • 562 posts
Posted June 12, 2014 - 02:25 PM
More updates. I acquired a Reversing fused contactor block from a forklift similar to what my electric motors came from. Should help with the pto motor control. Also bought a pair of used Ford LGT100 12x8.5 rear wheels I'm going to adapt. Not to mention I have the 2x3 steel to start on the new frame. :)
My car is almost done... just another panel to carpet. wife has given birth to my 2nd.. and I may finally have some time to get on this project.
Sent from my Z30 using Tapatalk
  • Clint and panzersarebest have said thanks
#50 BowDown ONLINE
BowDown
  • 551 Thanks
  • 562 posts
Posted June 13, 2014 - 12:32 PM
Contactor uploadfromtaptalk1402680753535.jpg uploadfromtaptalk1402680753535.jpg
#51 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted June 15, 2014 - 08:29 AM
Bowdown, I am excited to see you regain your momentum on this project, as I am sure many are, and can't wait to see it complete.
I do have one question for you though. Where in the world are you going to find room for the batteries? I have seen the workings of  electric golf carts, and such, and the batteries are huge!!!
#52 BowDown ONLINE
BowDown
  • 551 Thanks
  • 562 posts
Posted June 15, 2014 - 09:41 AM
Ya they are. I have a 2d cad sketch of the frame layout. Monday I can upload a picture of where things are going to fall.
I'm also thinking that I may sheet metal the sides of the front in. That way I can keep electrical accessible. Will hinge it for hot rod hood look.
#53 BowDown ONLINE
BowDown
  • 551 Thanks
  • 562 posts
Posted June 15, 2014 - 09:42 AM
Basically a battery box for 2 12v floor scrubber batteries will go directly in front of the rear sprocket. It will hang down about 5" and poke above the frame about 3".
#54 Texas Deere and Horse OFFLINE
  • 14,889 Thanks
  • 15,514 posts
Posted June 15, 2014 - 10:53 AM
Glad to see you moving ahead with this project. Can't wait to see it finished.
#55 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted June 15, 2014 - 11:03 AM
I am in the process of redoing my panzer right now, so mine is down to the frame right now as we speak. I cant possibly see how they would fit in there without cutting a bunch of stuff out of there, or making the frame longer? Here is a pic of mine with a standard lawn battery. That's without the rest of the stuff that normally would be in there.
Edited by stiemmy, June 15, 2014 - 11:22 AM.
#56 BowDown ONLINE
BowDown
  • 551 Thanks
  • 562 posts
Posted June 15, 2014 - 11:48 AM
Well I'm installing 2 electric motors not in the same OEM gas location. I'm stretching the frame 4". Also the tubes are going to be 2x3" box.
  • stiemmy said thank you
#57 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted June 15, 2014 - 12:17 PM
Ahh, I see. It will be interesting when done for sure. What do expect the discharge time to be with both motors running?
#58 BowDown ONLINE
BowDown
  • 551 Thanks
  • 562 posts
Posted June 15, 2014 - 01:19 PM
Thinking 75-90min. Not sure how much load will be on the motors doing the drive and mower deck. Going to install a couple shunts and meters to see.
#59 stiemmy OFFLINE
stiemmy
  • 2,537 Thanks
  • 1,830 posts
Posted June 16, 2014 - 06:28 PM
Too cool!! Keep up the good work. I'll be taggin along in weeds :)
#60 BowDown ONLINE
BowDown
  • 551 Thanks
  • 562 posts
Posted August 26, 2014 - 08:22 AM
Long gap here but the past few days during lunch I have made some progress on this project!
I cut up some of the 2x3 (.120 wall) tubing for the frame rails, and some 2x2 (.120 wall) tubing for the rear drive motor support, battery box support, and front pto motor support. I thought my work had some 2" OD tubing kicking around I could use for the Bolens front end attachment, but it's 2" ID so no go. I ordered up a 3ft short piece from eBay. After that arrives it's a matter of welding up the new frame structure. I'm thinking I will go period correct on the welds and stick it together... Maybe cheat a bit and use the mig for tacks.
In the meantime I finished dis-assembly of the tractor to the point I need it to be... I removed the front grill, steering, rear fenders, lift mechanism, and cut the original frame tubes off near flush with the rear end.
The new 2x3 tubes will rest on top of the rear end. I'm thinking I will weld a piece of angle iron on the inside similar to the fender mounts and bolt through the 2 brackets, tube, and fenders to attach the rear end to the frame rails. I'm also leaving about 1.5" overhang off the back of the tractor for a future rear 3pt hitch setup.
Sorry for the lack of pictures. When I get to welding and mockup on the rear end and new front assembly I will be sure to snap some pictures!
  • Clint said thank you
