* * * * * 1 votes
Just Got A 1968? Sears Custom 10Xl
24 replies to this topic
#16 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted July 13, 2013 - 06:37 PM
In the 10XL manual it says these trans use SAE 30 oil. That is what I put in mine.
Glad you got it up and running! I also had the problem with rust on the pulley.
  • EricFromPa said thank you
#17 MH81 OFFLINE
Posted July 13, 2013 - 09:23 PM
I went with the 5 qts of 80-90 in my stuff. As for how the water got in, around the gear shift is a big one. Making a rubber umbrella for the shifter is a good idea.
#18 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted July 13, 2013 - 09:55 PM
Alan Did yours have the SAE 30 originally? If so do you notice any difference using the 80/90?
I didn't check around before I changed my fluid I just put what the old manual suggested. But If it can handle it I would rather run the 80/90.
#19 MH81 OFFLINE
Posted July 13, 2013 - 10:00 PM
The only diff was it being a little quieter? Maybe?
I might consider running thinner stuff if I used them often in below zero temps.
  • chris m said thank you
#20 EricFromPa ONLINE
EricFromPa
  • 3,658 Thanks
  • 3,114 posts
Posted July 13, 2013 - 11:42 PM
I tore the shifter apart to replace the roll pin that was sheared off,I cut up an old Philips head screw driver that was stripped.That should last a while lol.There's a rubber seal on the top of the shifter ball but I packed the inside of the shifter with some Heavy grease.That should keep water out for a bit until I can find a rubber shifter boot.
I don't want to run the tractor any more until I get some fresh oil in the rear.It sounds pretty nasty in reverse.dry sounding.
  • Dane in PA said thank you
#21 EricFromPa ONLINE
EricFromPa
  • 3,658 Thanks
  • 3,114 posts
Posted July 14, 2013 - 09:20 PM
I found a part missing on my 10XL.I was wondering why it was hard to get it in gear and the deck doesn't disengage most of the time without monkeying with it a bit.
I'm missing the belt guard that bolts to the engine.Seems like someone didn't bother to put it back on.
#22 Dane in PA OFFLINE
Dane in PA
    Permanent Lurker
  • 552 Thanks
  • 616 posts
Posted July 14, 2013 - 09:30 PM
Ethan should have a few.
#23 Tulsawriter OFFLINE
Tulsawriter
  • 1 posts
Posted August 07, 2013 - 10:19 AM
I'm going to put a set of 23x10.50x12 turf tires on the rear.
Won"t these tire be too big for the wheel wells.  I put on some tire smaller and had to remove the wheel fenders to get them to fit.
Looks good I will post some pics of mine later.
OSU Cowboy Fan
#24 Golden Hurricane OFFLINE
Golden Hurricane
  • 16 Thanks
  • 24 posts
Posted August 08, 2013 - 07:43 AM
Love to see your pics Tulsawriter! Post 'em up...
#25 MH81 OFFLINE
Posted August 08, 2013 - 08:57 PM
If you find some really heavy wire like what they used, you can make do with a home made guide. Seen a lot of them, made a few, and they don't always look unsightly
