K181 Vacuum Pump Rebuild
10 replies to this topic
#1 motobreeder OFFLINE
motobreeder
  • 433 Thanks
  • 618 posts
Posted July 09, 2013 - 06:14 PM
I'm trying to rebuild my k181 vacuum/pulse fuel pump.  After some some searching, it's appears to be well-known that the rebuild kits have been NLA for quite some time.
What do I need to get to make a new membrane?  Where would I look for it?  Maybe that will translate to something in Canada.
Folks at Benson's sold me some rubber gasket material, but when I tried to flex it it tore.  That won't work.  Also, because it's for gas, rubber from an inner tube won't work.
Thanks.
Dwayne.
#2 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 13,313 Thanks
  • 9,782 posts
Posted July 09, 2013 - 07:05 PM
I'm not familiar with that pump. Can you show us a pic? Kit's are availabable  for the usual pumps.
#3 superaben OFFLINE
superaben
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted July 09, 2013 - 08:15 PM
Dwayne, if you hurry, post your Kohler model + type and I can check if my Kohler fuel pump kit is right.  It is on Ebay right now for $24, Kohler #236387.
For the diaphragm, you will need buna-nitrile rubber.  It is supposed to be the only stuff that will work.
Ben W.
  • motobreeder said thank you
#4 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted July 09, 2013 - 08:36 PM
... For the diaphragm, you will need buna-nitrile rubber. ...
As in Nitrile gloves?  The ones that don't dissolve when you play with gas?
Edited by New.Canadian.DB.Owner, July 09, 2013 - 08:36 PM.
  • motobreeder and superaben have said thanks
#5 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 13,313 Thanks
  • 9,782 posts
Posted July 09, 2013 - 08:48 PM
Ben W.
Is that the medical grade ones???
  • superaben said thank you
#6 motobreeder OFFLINE
motobreeder
  • 433 Thanks
  • 618 posts
Posted July 09, 2013 - 08:56 PM
Ben W.
Thanks Ben, I think I found your ebay listing.  It's for what I've read might be a special or sever duty pump.  Mine has 4 bolts.  Yours has 6.
But your answer regarding the material I need is really helpful.  I did some searching in google and it appears to be the same material used to make nitrile "rubber" gloves.
Was thinking a piece of nitrile glove may double up the existing gasket for now.  I will have to think about how the pump works and if the two layers will work.  I wouldn't trust the glove material by itself to be strong enough.
#7 superaben OFFLINE
superaben
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted July 09, 2013 - 09:29 PM
I personally wouldn't choose two layers for one diaphragm material, but you can see what you think from what your application requires.
I have bought buna-nitrile from McMaster Carr.  They sell it in various thicknesses.  I am working on reproducing Clinton fuel pump diaphragms.
I have this stuff:
http://www.mcmaster....-sheets/=njy8cz
That may be.  Do you want your diaphragm bubble gum flavored?
Ben W.
#8 motobreeder OFFLINE
motobreeder
  • 433 Thanks
  • 618 posts
Posted July 09, 2013 - 09:34 PM
I found the following - looks like there is a place that has taken on the task of re-making these kits.
http://www.maritimed...ohler_pumps.pdf
Depending on the S&H, this looks like a really good value.  I sent an email - waiting for a response.
Edited by motobreeder, July 09, 2013 - 09:35 PM.
  • chris m, boyscout862 and superaben have said thanks
#9 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted July 09, 2013 - 10:57 PM
That is amazing. I have been searching everywhere with no luck, trying to find a kit for you! And you find a place that reproduces them, and to top it of the place isn't even that far from me lol!
I just went to there site and it (Then and now automotive) looks and sounds like a great place. Thanks for finding and sharing this!
This will be a HUGE help to everyone that still has any of the Kohler metal (old) fuel pumps!
  • motobreeder and boyscout862 have said thanks
#10 superaben OFFLINE
superaben
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted July 10, 2013 - 06:06 AM
I think you hit the jack pot!  You need to ask them if you get a free fuel pump kit for referral.  I just sent an email, too.  :thumbs:
Ben W.
#11 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 13,313 Thanks
  • 9,782 posts
Posted July 10, 2013 - 06:56 AM
Yes, you beat me to it. I and others have quoted this site before. That's why I wanted a photo of your pump. I'm thinking of buying one of their kits so I can do a rebuild to post on here. There's no reason to toss your old pumps and buy a cheapo plastic pump.
