How Good Are The 10Hp Air Cooled Single Cylinder Diesel
10 replies to this topic
#1 searspullingtractor OFFLINE
searspullingtractor
  • 34 Thanks
  • 103 posts
Posted July 09, 2013 - 02:21 PM
are they good for pulling? can you get them worked?
#2 Cvans OFFLINE
  • 7,075 Thanks
  • 6,292 posts
Posted July 09, 2013 - 08:39 PM
From the research I've done some are good and others not so. It depends on the manufacturer. Carrol Stream seems to have a good reputation. The others are kind of hit and miss.
Edited by Cvans, July 09, 2013 - 10:55 PM.
  • Dieselcubmike said thank you
#3 EricFromPa OFFLINE
EricFromPa
  • 3,978 Thanks
  • 3,248 posts
Posted July 09, 2013 - 10:29 PM
I've seen a couple of them melt down,Don't know if it was the valve seats or just a poorly ground cam shaft but they're not pretty when they go.And 1 runaway because of a factory broken ring.
I'm not sure if I would trust one for pulling.You will be running flat out and more than likely you will be torquing out.(running it flat out with Full load till it stalls)I'm not sure that they are built well enough for that.And if it were to blow a rod,where would you get parts for it locally?
I would trust one for pulling a plow or mowing the yard or pulling a cart but that's about it.
Edited by EricFromPa, July 09, 2013 - 10:31 PM.
  • Cvans and Dieselcubmike have said thanks
#4 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted July 09, 2013 - 11:17 PM
I agree with chris and eric. Really all the more good theyre worth or mowing duty and plowing but that's the extent of it. If you want a diesel for pulling save yourself some money and get a cub and a good diesel motor.
  • Cvans said thank you
#5 broken2 OFFLINE
broken2
  • 280 Thanks
  • 425 posts
Posted July 09, 2013 - 11:20 PM
I don't know a whole lot about them but have been planning to use one to repower one of my mf10's. From what I understand they are a Chinese clone of the Yanmar diesel. The Yanmar singles have a good reputation but I doubt the Chinese use the same quality materials and manufacturing. Either way I want one and if I get one I will test it's limits and durability for sure. I've seen a few of them at plow days and was impressed buy the power they they had. One guy had one that was only a 4.5hp in a mf10. He was working the hell out of that thing, it was underpowered but still impressive for a 4.5hp. He and his friend also had a couple of JD's,112's I think, with 6hp's in them and they seemed to pull a brinly 10" fine. They were noisy and poured a lot of smoke. I would definitely go with a 10hp. Carrol Stream seems to have a good reputation as a distributor for them. Here's a couple pics I dug up of the 4.5 massey and the 6.0 jd's.
#6 broken2 OFFLINE
broken2
  • 280 Thanks
  • 425 posts
Posted July 09, 2013 - 11:36 PM
Like the the others said I don't think I would use one for a pulling tractor, but I would like to see someone else do it so I could see what happens! This Allis d10 supposedly has a Carrol Stream 10hp diesel in it:
Edited by broken2, July 09, 2013 - 11:45 PM.
  • JD DANNELS, Cvans and 18pointer have said thanks
#7 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted July 10, 2013 - 01:37 PM
That's quite the ditch digger!!
#8 Kalder OFFLINE
Kalder
  • 9 Thanks
  • 13 posts
Posted August 11, 2013 - 03:08 PM
If you look on ebay, most of the Yanmar L100 parts interchange with the Chinese clones.
#9 baerpath OFFLINE
baerpath
  • 314 Thanks
  • 514 posts
Posted August 18, 2013 - 05:52 AM
Just like any other engine, their great until they break,  A lot of the clones used a nylon cam gear that could strip out. Beleive the newer ones are better. Seen a lot of them on the tracks in the past couple of years.
#10 64CubCadet OFFLINE
64CubCadet
  • 3 Thanks
  • 6 posts
Posted September 29, 2013 - 08:51 PM
Would be interesting to know if there worth the trouble to do the conversion,or if they will actualy put out the power needed to mow etc continusly
#11 motobreeder OFFLINE
motobreeder
  • 433 Thanks
  • 618 posts
Posted October 01, 2013 - 09:24 AM
Not an answer to the mowing question, but here's a 10hp chinese diesel (powerfist that Princess Auto used to sell).
https://www.facebook...151608648352653
It has gone through a few modifications and rebuilds.  Definitely entertaining.
