Lister Lt-2 Diesel--Good Choice To Repower Jd420?
lister lt2 diesel repower lt2 jd420 diesel repower jd420
12 replies to this topic
#1 Utah Smitty ONLINE
Utah Smitty
  • 1,705 Thanks
  • 1,791 posts
Posted July 07, 2013 - 05:53 PM
I've come across a Lister LT2 diesel engine that a guy bought for a boat, but never used.  It's electric start, 2 cylinder  vertical pistons, with CCW flywheel rotation when viewed at the flywheel end.
I haven't seen the actual engine, only a picture.
I've been able to find a repair manual, which lists a 3.25" x 3.0" bore, direct injection, plunger type oil pump, etc., but no mention of horsepower, torque, engine weight or dimensions.
I'm looking for an eventual repower of my JD420.  Would this be a good choice? I think someone on the forum has used Listers to repower GTs, but can't find the link...
Regards,
Utah Smitty
Edited by Utah Smitty, July 07, 2013 - 05:55 PM.
#2 olcowhand ONLINE
  • 42,342 Thanks
  • 31,784 posts
Posted July 07, 2013 - 05:55 PM
I've come across a Lister LT2 diesel engine that a guy bought for a boat, but never used.   I think someone on the forum has used Listers to repower GTs, but can't find the link...
Regards,
Utah Smitty
That would be Chris, aka member "cvans"
  • Utah Smitty said thank you
#3 olcowhand ONLINE
  • 42,342 Thanks
  • 31,784 posts
Posted July 07, 2013 - 05:57 PM
HERE is a link to one of his Lister Petter projects.
#4 Utah Smitty ONLINE
Utah Smitty
  • 1,705 Thanks
  • 1,791 posts
Posted July 07, 2013 - 07:41 PM
I found and uploaded a workshop manual for the Lister L-series engines, plus a parts manual for the LT1 and LV1 single cylinder versions.
Smitty
#5 JDBrian OFFLINE
  • 9,641 Thanks
  • 14,156 posts
Posted July 08, 2013 - 05:08 AM
Smitty, those marine engines are sometimes designed to run at lower rpms but will last virtually forever if maintained. Likely it will be bigger and heavier than a gas engine. If you can't find any info try a small diesel engine forum.
#6 Utah Smitty ONLINE
Utah Smitty
  • 1,705 Thanks
  • 1,791 posts
Posted July 08, 2013 - 05:13 AM
Thanks, Brian.
I found a British site that listed basics... 300 lbs,14 hp @ 3600 rpm... The workshop manual also gives specifics of the build code, but I don't know what that is.
I discussed it on PM with Cvans and it looks like it doesn't have the hp I would want for the JD420... oh, well!!
Smitty
#7 JDBrian OFFLINE
  • 9,641 Thanks
  • 14,156 posts
Posted July 08, 2013 - 07:59 AM
Not only that but the weight, 300lbs -that's a huge increase over the 125 or so of the Onan. I think 14hp would work fine for loader work but for PTO work like running a large deck it may be limited compared to a higher HP alternative. I think the most common repower kit for the older JD's is the Band S Vanguard V twins but the price is a bit shocking at 1500$ +! You'll eventually come up with a repower that works!
#8 olcowhand ONLINE
  • 42,342 Thanks
  • 31,784 posts
Posted July 08, 2013 - 08:31 AM
Yes, just running the loader, even 12hp would be enough, as I just run my 16hp Yanmar in my Massey at a fast idle when doing loader work, and it's plenty of power, but as Brian said, any pto work, and you'd be singing the blues.
#9 Cvans ONLINE
  • 7,068 Thanks
  • 6,286 posts
Posted July 08, 2013 - 09:51 AM
Sure would be fun to play with though. As a novelty project it would be really neat.
#10 JDBrian OFFLINE
  • 9,641 Thanks
  • 14,156 posts
Posted July 08, 2013 - 10:24 AM
I bet it would be a hard fit into the engine bay as well. At 300 lbs it's got to be a big beast.
#11 Utah Smitty ONLINE
Utah Smitty
  • 1,705 Thanks
  • 1,791 posts
Posted July 08, 2013 - 03:28 PM
The largest dimension is the height--approx. 19".  It's about 18" square length and width...
There's a British company - DEV Engineering, that has info on them as well as builds parts for vintage engines.
Smitty.
#12 Cvans ONLINE
  • 7,068 Thanks
  • 6,286 posts
Posted July 11, 2013 - 03:07 PM
Here you go Smitty. I've not seen one of these before but it has the horse power.
http://minneapolis.c...3884309323.html
  • olcowhand, Texas Deere and Horse and Utah Smitty have said thanks
#13 Utah Smitty ONLINE
Utah Smitty
  • 1,705 Thanks
  • 1,791 posts
Posted July 13, 2013 - 01:26 PM
Thanks for the info, Chris.  I checked into it as the price was tempting.  It's an Acme 740--built in Italy. Bought out by Lombardini, who was bought out by Kohler.  The Acmes were good engines, but ran rough, and tended to crack frames on GTs if installed in them (per one of the parts sources I contacted). The parts for them are drying up as well since they are no longer built...
I'll have to pass on this one, though the seller also has a VW turbo that he bought for it, and wants to sell it as well, if anyone is interested
Regards,
Smitty
  • Cvans said thank you
Also tagged with one or more of these keywords: lister lt2, diesel repower, lt2, jd420 diesel repower, jd420
