Needing Help With Our Ariens S-8 Garden Tractor Made Between 1974-1978
12 replies to this topic
#1 Sunflower79 OFFLINE
Sunflower79
  • 3 posts
Posted July 06, 2013 - 11:11 PM
We are needing any information on our Ariens S-8 Hydrostatic garden tractor made between 1974-1978, the Ariens company does not have any info on these tractors anymore...but I sent them pictures of it and they think the model number is 929002. We can't figure out how to get the deck on to cut the grass, need to know what fuel it takes, there is a fuel leak of some sort and the battery won't keep a charge. Anyone able to help that would be great.
#2 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted July 07, 2013 - 12:15 AM
I have been searching for you, not a lot of info out there on these.
I see it is a LT and not a GT, and should be a 8 hp Briggs vertical shaft engine.
If you Google (or Bing) Ariens 929002 there are some PDF manuals out there. I just don't know the sites and didn't want to post a link. So I took a picture of the Deck mount page in the owners manual.
The other issues could be any number of things. Fuel leak could be a gummed up carb from sitting for a long time, a bad fuel line etc...
The Battery not holding a charge could be a Old (Bad) battery, bad connections or a stator problem ect..
This engine would run on reg unleaded gas. and the oil for the engine ( not mixed in gas) would be any SAE 30 oil.
If you have pictures or could explain anything you have checked already it would help us determine what else may be causing a problem.
Also If you could get the model, serial and type numbers off the Briggs engine, that would help too.
  • Sunflower79 said thank you
#3 JDBrian OFFLINE
  • 9,635 Thanks
  • 14,156 posts
Posted July 07, 2013 - 05:16 AM
Welcome to GTTalk. Looks like info. is scarce for your mower. As Chris suggested above, try posting some pictures or asking specific questions about each problem on the Ariens forum.
#4 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted July 07, 2013 - 06:17 AM
:welcometogttalk:
#5 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted July 07, 2013 - 06:18 AM
:wewantpics:
#6 Sunflower79 OFFLINE
Sunflower79
  • 3 posts
Posted July 07, 2013 - 08:28 AM
Ok, so I figured out how to do the profile pic...how do I post pics for you guys to see? I'm a rookie at this. I had bought the tractor for my husband...the man I bought it off of was over an hour late dropping it off. I had to leave to get my kids from school, so I wasn't able to ask him anything about the tractor and I have lost his phone number. So I've been searching for info all over the internet.
#7 drbish ONLINE
drbish
    Collecter
  • 1,571 Thanks
  • 1,370 posts
Posted July 07, 2013 - 09:33 AM
I have a repair manual for the 935 series after you get a picture of the deck I will see if it is the same and will get the info for you
#8 drbish ONLINE
drbish
    Collecter
  • 1,571 Thanks
  • 1,370 posts
Posted July 07, 2013 - 11:14 AM
I do not believe this is the same deck as the picture you sent me.It may be off some help anyway.
Sorry about the quality of the pages .I could not get the top shut on the copier as it is a thick book
Attached File  Ariens 935 mower deck.PDF   3.05MB   181 downloads
#9 drbish ONLINE
drbish
    Collecter
  • 1,571 Thanks
  • 1,370 posts
Posted July 07, 2013 - 12:18 PM
About your fuel leak issue it is hard to say what is wrong.where is it coming from?The carb,gas line,fuel filter.How old is the battery.It probably
would be the first thing to check.Take it to a place that sells batteries and have them check it for you.
Good luck
#10 drbish ONLINE
drbish
    Collecter
  • 1,571 Thanks
  • 1,370 posts
Posted July 07, 2013 - 12:28 PM
Here is some pictures of the deck and engine side of the Ariens .
#11 Sunflower79 OFFLINE
Sunflower79
  • 3 posts
Posted July 08, 2013 - 08:11 PM
The label that says model number and serial number are blank. Just the line where the numbers should be.
#12 jbrueg82 OFFLINE
jbrueg82
  • 1 posts
Posted July 03, 2014 - 11:27 PM
runs and mows 8 hp 36 in cut Ariens 929002
WP_20140625_001.jpg WP_20140625_008.jpg WP_20140625_002.jpg WP_20140625_003.jpg WP_20140625_004.jpg WP_20140625_006.jpg WP_20140625_007.jpg WP_20140625_005.jpg
#13 shorty ONLINE
shorty
  • 5,769 Thanks
  • 5,389 posts
Posted July 05, 2014 - 05:26 AM
Welcome to the forums jbrueg82!
  • jbrueg82 said thank you
