What Will 24X12-12 Look Like On 8.50 Rims
4 replies to this topic
#1 searspullingtractor OFFLINE
searspullingtractor
  • 34 Thanks
  • 103 posts
Posted July 06, 2013 - 10:48 PM
will they do the same thing as 26x12-12 on a small rim. does any one have pics thanks
Edited by searspullingtractor, July 06, 2013 - 10:49 PM.
  • larryd said thank you
#2 Ryan313 OFFLINE
  • 3,369 Thanks
  • 5,231 posts
Posted July 06, 2013 - 11:24 PM
Since the tire is not any skinnier, I think it would do the same thing. Actually, I think it would be worse! On a 26x12x12 there is 6 inches (differs slightly between brand and tread) of rubber around the wheel, on a 24x12x12 you only have 4 inches around the wheel. A tire 12 inches wide, on an 8.5 wheel will be pulled in 1.75 inches on each side. When the 1.75 inches are spread over 6 inches it is not as drastic as it is when it is spread over 4 inches.
In conclusion, when the 24x12x12 tires are compared to the 26x12x12 tires they will be 33% worse. At least in theory anyway...
  • 14,814 Thanks
  • 15,501 posts
Posted July 06, 2013 - 11:27 PM
I would like to see how they look mounted up..
#4 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted July 07, 2013 - 05:12 AM
For the Carlisle turf tire 8.5 is the correct width! http://www.carlislet...arden-golf/Ti15
#5 baerpath OFFLINE
baerpath
  • 314 Thanks
  • 514 posts
Posted July 07, 2013 - 07:26 AM
On the AT 101's the side wall is not straight, so the narrower rim is right. They will hook better then a 23 x 10.50 but a 26 x12 will out hook them
