Mower Blade Speed
24 replies to this topic
#1 Alc ONLINE
  • 6,740 Thanks
  • 7,395 posts
Posted July 04, 2013 - 03:20 PM
Is it me or do the newer mowers run a faster blade speed and if that,s better would it be worth changing the deck pulley to spin the faster on a older mower ?
  • dropped82 and JRJ have said thanks
#2 JDBrian OFFLINE
  • 9,601 Thanks
Posted July 04, 2013 - 04:03 PM
It's possible Al. Look at the size of the motors they run. 25HP is common now versus 14-18 on the older machines.
  • Alc and dropped82 have said thanks
#3 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,970 Thanks
  • 9,615 posts
Posted July 04, 2013 - 04:06 PM
I think there is some kind of safety rule about the tip speed of the blade. It can only run so fast. If it is a shorter blade, 20" vs 22", It can turn more rpms to get the same tip speed.
  • Alc, JDBrian and dropped82 have said thanks
#4 dropped82 ONLINE
dropped82
    Nut Case
  • 2,447 Thanks
  • 1,794 posts
Posted July 04, 2013 - 04:25 PM
I was wondering the same thing. I've considered changing the pulley on my Case 226 48" deck. I figured the onan had enough power.
Eric
Sent from my XT897 using Tapatalk 2
#5 Alc ONLINE
  • 6,740 Thanks
  • 7,395 posts
Posted July 04, 2013 - 05:32 PM
Eric I was thinking the same my 318 now has a 20hp on it so maybe would changing the pulley give me a better cut ? I run it wide open and almost full speed but thats because it doesn't cut well full speed ok I'm really running it too fast now , I should being slower runn lol
  • dropped82 said thank you
#6 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,970 Thanks
  • 9,615 posts
Posted July 04, 2013 - 05:43 PM
Just know that the faster it turns, the faster it will throw a rock!
#7 dropped82 ONLINE
dropped82
    Nut Case
  • 2,447 Thanks
  • 1,794 posts
Posted July 04, 2013 - 05:50 PM
Well the only reason I want to increase blade speed is so I can raise my tractor speed some. I don't want to run full bore but would like to move a little faster. I just figured blade speed is the reason why the Dixie Choppers and Scags can mow so fast. I know they have a lot of PTO power too. In the same sense I have no intentions on going that fast. I've read somewhere about John Deere having a step up kit for their decks. I can't find it anymore.
Eric
#8 dropped82 ONLINE
dropped82
    Nut Case
  • 2,447 Thanks
  • 1,794 posts
Posted July 04, 2013 - 05:51 PM
Honestly with the way my 226 throws grass out now, I could see throwing grass in the neighbors yard after an upgrade lol.
Eric
#9 HydroHarold OFFLINE
HydroHarold
  • 703 Thanks
  • 977 posts
Posted July 05, 2013 - 01:20 AM
Didn't our esteemed congress limit blade tip speed some years ago on homeowner mower/tractors?  "Commercial" machines got more leeway in top blade speed.  I remember this discussion years ago on Satan'sTractorForum.  Supposedly the JD "7 Iron" deck gets a faster speed as it's related to "commercial turf equipment" and the same size "yellow decks" are slower turners...
I know the ZeroTurn that does my neighbor sounds like it's going half again faster than my 48C @ WOT.
#10 Alc ONLINE
  • 6,740 Thanks
  • 7,395 posts
Posted July 05, 2013 - 05:48 AM
Well did a search and found this dated 1995  telling dealers to drop the blade spped to 19,000 fpm from 21,000 , guessing that was just for home owners . Anyway think maybe I should just measure my pulleys and do a little math, borrow the non-contact tach from work  just to see where I'm at before changing anything .
  • Attached File  1071.pdf   10.89KB   409 downloads
  • MH81, Bruce Dorsi, Bmerf and 1 other said thanks
#11 dropped82 ONLINE
dropped82
    Nut Case
  • 2,447 Thanks
  • 1,794 posts
Posted July 11, 2013 - 11:12 PM
I did some research and math tonight and this is what I found. I have a 226 with the H46 48" deck. My drive pulley is 5" and the driven pulley is 4.75". With the 17" outer blades I'm getting approximately 16390 FPM. In comparison the Hustler Z has 18100 FPM which allows it to mow at 15 mph. Now I understand that deck design plays a part and in no way expect or want to mow at 15mph. So I have a 38" deck which has a 4.25" pulley on it. Doing the math I will have a speed of 18300 FPM with changing to that pulley. I don't want to go over 19000 FPM. That's seems a little unsafe for my neighbors. I'm going to try this swap and see what happens. Of course I just mowed so my findings will have to wait 4 more days for some grass to grow. I'm also going to rebalance and sharpen again to try to eliminate any variables. I want to make sure everything is in top notch condition before cranking the Franken-deck on lol. Wish me luck!
Eric
Eric
#12 drbish ONLINE
drbish
    Collecter
  • 1,555 Thanks
  • 1,358 posts
Posted July 12, 2013 - 04:41 AM
Here is a  Service Bullentin that  Clinton Engines issued in 1958,pertaining to blade speed of rotary mowers
Some interesting info
Attached File  clintonBlade speed.PDF   2.13MB   104 downloads
  • Cvans, chris m, dropped82 and 1 other said thanks
#13 bgkid2966 OFFLINE
bgkid2966
  • 1,411 Thanks
  • 1,331 posts
Posted July 12, 2013 - 07:27 AM
I just use an MTD push mower for my postage stamp city lot. I raised the RPM of the Briggs 6.5 hp engine so it would mulch better. I am not
going to walk any faster with it! It does seem too mulch better, so it was worth doing in my opinion.
Geno
#14 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,970 Thanks
  • 9,615 posts
Posted July 12, 2013 - 12:44 PM
You took the discharge flap off, didn't you?
#15 dropped82 ONLINE
dropped82
    Nut Case
  • 2,447 Thanks
  • 1,794 posts
Posted July 12, 2013 - 01:10 PM
The case deck has the chute built in. Its fixed.
Eric
