Simplicity Power Max 4041 Questions..
2 replies to this topic
#1 Texas Deere and Horse ONLINE
  • 14,858 Thanks
  • 15,510 posts
Posted July 04, 2013 - 03:09 PM
Since I'm working today at the shop, I got a chance to pull the 4041into the shop and look it over a little more. I have found a few things that need to be fixed to make it a good worker.
1. There is no element left in the air filter, will replace before we do anything else.
2. To get the engine to run proper, the choke is half on, it has 3 positions and it's set in the middle to run smooth, I will need to adjust the Carb and see if I can get it run enough without the choke.
3.Both exhaust manifolds have broken bolts and/ or flanges. It appears that one side had been welded or something.
4. Get the battery back up front and locked down in the proper place, the heat shield is there so I don't know why they moved it.
5. Get the rest of the engine tin work for it and get them installed. Thanks to Daniel and Kenny P., I have a few options on where to get them.
6. The Hydraulics operate backwards, to lift the deck you have to push the lift lever forwards instead of pulling to back, so I'm going to have to look at the lines to and from the valve body and see if they have been switched at one time.
7. Can you buy these rubber straps anywhere, they hold the hood closed.
8. Is this the original steering wheel, it looks more like a sports car wheel then a tractor wheel.
  • hamman and JRJ have said thanks
#2 superaben OFFLINE
    Con Man
  • 7,669 Thanks
  • 5,677 posts
Posted July 04, 2013 - 09:20 PM
Brian, somebody told me that the straps to hold down the hoods on Steiner/Ventrac articulated machines are similar to the old style hold downs.  I've never compared, but it was an idea in the back of my head in case I needed it.
Ben W.
#3 B10Dave OFFLINE
  • 788 Thanks
  • 350 posts
Posted July 04, 2013 - 09:30 PM
Hood straps are available through Simplicity dealer. Try Sandy Lake Implement in Sandy Lake Pa. Google it and give Brenda a call. And yes it is the wrong steering wheel. Proper one looks like wheel on the Allis700/Simpl.7000 series tractors....Dave
