Sold
Need Scrap Steering Shaft
6 replies to this topic
#1 glgrumpy ONLINE
  • 8,612 Thanks
  • 7,920 posts
Posted July 04, 2013 - 01:03 AM
Have my Grumpy King and steer wheel is too low. I want to lengthen the column up about 6", but want to do it with an adapter and leave orig column as is. Adapter will be made from old steer wheel center, which I have now and some metal rod or ?? not sure yet welded to it and a section of the top of a donor shaft. I need the splines and good threads to mount that wheel up higher in orig configuration. Need about 6 " at least with good splines and threads if anyone has one they are more less scrapping and would sell me and ship. Thanks!
Edited by MH81, July 23, 2013 - 04:28 PM.
  • larryd and JRJ have said thanks
#2 Bob 537 OFFLINE
Bob 537
  • 68 Thanks
  • 127 posts
Posted July 04, 2013 - 05:33 AM
I bought my plow from this guy Gary out in NY he said he had a real good steering colum if your still looking for one ill send you his email in a PM
#3 CRFarnsworth ONLINE
CRFarnsworth
  • 4,675 Thanks
  • 2,146 posts
Posted July 04, 2013 - 07:11 AM
Just got  an old JD 110 that is junked out.  You can have the steering shaft out of it.  It'll take a little while to work the wheel off of it. But as soon as I do it's yours for the shipping cost if you want it.  Rick
#4 glgrumpy ONLINE
  • 8,612 Thanks
  • 7,920 posts
Posted July 04, 2013 - 01:25 PM
OK, NO New shaft needed!  Just a junker piece for the end.  I'm leaving my orig shaft as is.  Deere have splines and nut for wheel? Not sure if same as PK. I have couple PK fellas as leads now, think I might be good, will check back.
#5 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted July 05, 2013 - 04:43 PM
The Power Kings used Ross Steering boxes, as did most garden tractors; the splines on every Ross steering box is the same (as far as I know) so you should be able to use a shaft from almost any GT.
#6 glgrumpy ONLINE
  • 8,612 Thanks
  • 7,920 posts
Posted July 23, 2013 - 03:28 PM
Have Now gotten a shaft part and am good, thanks!
#7 olcowhand ONLINE
  • 41,192 Thanks
  • 31,428 posts
Posted July 23, 2013 - 03:43 PM
He got the shaft, and is thankful!   :rolling:
Also tagged with one or more of these keywords: sold
