"in A Pinch" Belt
15 replies to this topic
#1 trackcar OFFLINE
trackcar
  • 28 Thanks
  • 52 posts
Posted July 03, 2013 - 10:17 PM
Today while mowing with my CC 2155, my pto belt that runs the deck got cut. My bad on that one. Anyway, we needed to complete the mowing before the rain came and we'll need the mower tomorrow at another location. The belt is 5/8" x 112 1/4" inches (# 754-3055A MTD) according to the store that would normally have one in stock. The best they could come up with is a generic one that is 5/8" x 112". I thought the 1/4" difference in length would be okay "in a pinch". Am I okay in that assumption??
Edited by trackcar, July 03, 2013 - 10:19 PM.
  • boyscout862, larryd and JRJ have said thanks
#2 Jack OFFLINE
Jack
  • 1,322 Thanks
  • 868 posts
Posted July 04, 2013 - 12:48 AM
I would think it would work...
  • trackcar and larryd have said thanks
#3 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted July 04, 2013 - 04:56 AM
Should work. I can't imagine 1/4" shorter would be that big a difference.
  • trackcar said thank you
#4 boyscout862 OFFLINE
  • 13,559 Thanks
  • 9,433 posts
Posted July 04, 2013 - 06:00 AM
I it should work. Let us know how it worked. Good Luck, Rick
#5 MH81 OFFLINE
  • 29,979 Thanks
Posted July 04, 2013 - 06:08 AM
The belt would normally stretch more than that. Should be fine.
Besides, considering the manufacturing tolerances of most countries making this stuff anymore, if its close, it's "close enough"... may end up buying one that is 112.25 by accident.
  • Alc and trackcar have said thanks
#6 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,149 Thanks
  • 10,211 posts
Posted July 04, 2013 - 07:01 AM
Hey, I read a story woncet about using a ladies panty hose for an emergency belt for a car. You could try that and let us know how it works for you, hmmm?
  • Lmiller3358 and trackcar have said thanks
#7 trackcar OFFLINE
trackcar
  • 28 Thanks
  • 52 posts
Posted July 04, 2013 - 07:07 AM
The belt is made here in the U.S. of A. by Outdoor Power Equip.  Still cost $43 w/tax. I'm hopin' that's normal. Worked fine yesterday.
  • MH81 and boyscout862 have said thanks
#8 CRFarnsworth OFFLINE
CRFarnsworth
  • 5,179 Thanks
  • 2,256 posts
Posted July 04, 2013 - 07:14 AM
I assume you have to remove the "Lady" first? :D  :D  Rick
#9 MH81 OFFLINE
  • 29,979 Thanks
Posted July 04, 2013 - 07:16 AM
Really, made here?  :dancingbanana:
Wow, that's refreshing. :thumbs:
#10 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,149 Thanks
  • 10,211 posts
Posted July 04, 2013 - 07:18 AM
I let her do that. It's quieter!!!
#11 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted July 04, 2013 - 07:32 AM
I've made do with small(er) belts.  As long as you have a good idler pulley with a strong tightener spring, then you will be in great shape.
Ben W.
  • CRFarnsworth said thank you
#12 boyscout862 OFFLINE
  • 13,559 Thanks
  • 9,433 posts
Posted July 04, 2013 - 07:56 AM
It was an emergency back up to use a nylon stocking for a fan belt years ago. You twisted it tight and tied a small knot, then trimmed it so it wouldn't jump off the pulleys. You kept the speed down and you could get a few miles out of it. Usually they would stretch and come off. I got longer times when bypassing the alternator. It wasn't worth the effort unless you are really in a bad place (like her dad's curfew). Good Luck, Rick
#13 KC9KAS OFFLINE
KC9KAS
  • 5,469 Thanks
  • 4,725 posts
Posted July 04, 2013 - 07:59 AM
If you didn't, it would really "squeel"
#14 KC9KAS OFFLINE
KC9KAS
  • 5,469 Thanks
  • 4,725 posts
Posted July 04, 2013 - 08:00 AM
Wouldn't her dad be just as upset knowing you took her panty hose?
  • CRFarnsworth and LilysDad have said thanks
#15 Lmiller3358 ONLINE
Lmiller3358
  • 1,549 Thanks
  • 1,460 posts
Posted July 04, 2013 - 11:25 AM
The tough part is you need be wearing panty hose when that happens , but is does work !
  • LilysDad said thank you
