Jd 317 Pricing
7 replies to this topic
#1 Kevin Vasich OFFLINE
Kevin Vasich
  • 87 Thanks
  • 174 posts
Posted July 03, 2013 - 09:55 PM
Hey One question Is $300 a great price for a 317. It's at swap meet it's didn't sell the first time it's going to be there the again. It's run and drives with deck not in bad shape.
  • JRJ said thank you
#2 adamjd200 OFFLINE
adamjd200
  • 2,084 Thanks
  • 2,201 posts
Posted July 03, 2013 - 09:58 PM
Not too bad of a price i've seen them go for more in the same condition.
#3 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted July 03, 2013 - 10:02 PM
I have seen them go for 5 times that!
http://minneapolis.c...3851825269.html
Edited by anderson classic tractors, July 03, 2013 - 10:34 PM.
  • 14,862 Thanks
  • 15,511 posts
Posted July 03, 2013 - 10:03 PM
I think it's a good price, do you know which engine it has in it. KT 17 Series 1 or 2? Or maybe a repower Onan?
#5 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,797 Thanks
  • 4,292 posts
Posted July 03, 2013 - 10:43 PM
the price is good, when the technic components of the tractor are in order.
#6 JDBrian OFFLINE
  • 9,644 Thanks
  • 14,158 posts
Posted July 04, 2013 - 04:53 AM
Lots of expensive bits to check if you don't have spares. Drive shaft, motor mounts, steering components - spindles wear at the axle. Series 1 engines can still work well if never used on side hills but all the engines can be ripe on these. Rear wheel bearings -lift the rear end and check the wheels for end play. If you find any, chances are the bearings are on their way out. Very hard to find bearings except at JD for like 100$ ea. You can get axles with bearings from used parts suppliers.
  300 is a good price but be wary of the expense of fixing one of these up if it's worn out!
#7 jms180 ONLINE
jms180
  • 1,627 Thanks
  • 1,621 posts
Posted July 04, 2013 - 08:22 AM
I think that is a good price. There was one listed here for 250 with bad engine.
#8 twostep OFFLINE
twostep
    Rockstar
  • 1,987 Thanks
  • 2,538 posts
Posted July 09, 2013 - 08:23 AM
Did you get this??
If the deck is solid with good spindles it alone is worth $300!!
