New Red Neck Design (Pics)
19 replies to this topic
#1 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted July 03, 2013 - 07:50 PM
Fresh from the "What the %#*$^ do you call that" shop, my latest creation.  Yeah, it's rough, but when you build it out of old trampoline parts and a $5 trailer frame, what do you expect?  It is, however, functional.  A few years ago I buit the hill billy water tower out back.  After several years of carrying water out front to the garden I said enough.  I found the trailer frame on Craigslist for $5.  Hacked off the wheels, axles and whatever held them on, got new plates made at work, new axle and wheels from Harbor Freight and the trailer part was done.  Mounted a 55 gallon plastic barrel on wooden cradles, strapped it down and built the framework up around it.  I then mounted a 12 volt pump which I can hook right to the tractor battery, built piping inside the barrel to get as much water out as possible and installed a hose with a wand on which I put an on/off switch.  I'm still working out the bugs but it works and takes a lot of out of watering the garden.
  • olcowhand, MH81, Alc and 4 others have said thanks
#2 MH81 OFFLINE
Posted July 03, 2013 - 07:51 PM
Sounds like that needs a patent LOL
  • David Brown said thank you
#3 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted July 03, 2013 - 07:55 PM
If it works do not knock it!! Your way ahead of me.I need a system like that!!
#4 lyall ONLINE
lyall
  • 2,171 Thanks
  • 1,574 posts
Posted July 03, 2013 - 08:22 PM
always thinking is the best reason to make something that is usable
is the spring the sump pump runs and I run the line to the street
now it a can find a 1000 gal tank to pump it into and save the water for summer time watering
#5 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,873 Thanks
  • 10,046 posts
Posted July 03, 2013 - 08:53 PM
What part is the trampoline?
#6 olcowhand ONLINE
  • 42,399 Thanks
  • 31,803 posts
Posted July 03, 2013 - 08:56 PM
I'd say the uprights are the trampoline legs???
#7 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted July 03, 2013 - 09:12 PM
Yes, that's correct.
#8 Arti ONLINE
Arti
  • 1,366 Thanks
  • 990 posts
Posted July 03, 2013 - 09:27 PM
Great idea.
#9 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted July 03, 2013 - 09:48 PM
Now that is neat and well engineered. We use a trailer, 250 gallon tank, pump, generator and wand. Usually use the Farmall H to pull it. The only bad thing is tying up the trailer.
#10 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted July 03, 2013 - 10:01 PM
You know I saw pictures of a garden where they had set 55 gal plastic drums up at the head of the garden.
Then the water gravity fed into trickle pipes ran down the rows.
  • lyall and David Brown have said thanks
#11 Cvans ONLINE
  • 7,076 Thanks
  • 6,293 posts
Posted July 03, 2013 - 10:09 PM
Don't see one thing wrong with your tanker. Especially the price.  :thumbs:
#12 KennyP OFFLINE
  • 40,136 Thanks
  • 46,765 posts
Posted July 03, 2013 - 10:19 PM
Cool tank trailer! Can't beat something that works!
#13 lyall ONLINE
lyall
  • 2,171 Thanks
  • 1,574 posts
Posted July 04, 2013 - 12:12 AM
Coke  gives the white 55 gal tanks away for free
people get them and sell them for around $15 each
got to check to see how many I can get
  • David Brown and LilysDad have said thanks
#14 HDWildBill OFFLINE
  • 8,978 Thanks
Posted July 04, 2013 - 10:29 AM
That is a great Idea and the price looks great too.  You mentioned you hook the pump up to the tractor battery, you didn't mention how you made the connection but one way I have done this, is to use a two prong connector
Split it and connect on side to the battery terminals and reverse the wiring and connect it to the pump wiring.  It has a good connection but if you forget to disconnect the wiring when you take the trailer off the tractor no big deal because it will disconnect as you pull away.  Just a thought.
#15 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted July 04, 2013 - 10:47 AM
And a good thought at that.  Thank you.  I use two alligator clips to connect to the battery.  Since the wires get strung over the seat, I don't usually forget to disconnect them.  I am, however, always looking for ways to improve the design.  I'll mark this one in case I get the urge to change it up a little.
  • HDWildBill said thank you
