Terramite 2
1 reply to this topic
#1 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted July 03, 2013 - 04:16 PM
Information on the Terramite 2:
  • grand, daytime dave and sacsr have said thanks
#2 milkdud OFFLINE
milkdud
  • 67 Thanks
  • 68 posts
Posted September 10, 2013 - 05:35 PM
Thats it.  The frame is a giveaway.  The Terramite has that beefier frame.   And this is listed in the specs.  Economy Tractor - 14 H.P. Power King. Transports and operates at 1650 psi, gear type hyd~auljc p u m p , s u p p l y i n g p o w e r t o a 6 S p o o l control valve (on the backhoe) and a 2 Spool control valve (on end loader) through 4000 psi, hydra ... l;c lines with heavy-duty fittings V alves are set at 1650 psi. Nine tractor speeds forward from Y2 to 5 miles per hour plus three reverse.
