Fuel Pump On The Fritz! Chuck It Or Rebuild It Again?
2 replies to this topic
#1 Moosetales OFFLINE
Moosetales
    Always learning something!
  • 1,089 Thanks
  • 1,284 posts
Posted July 02, 2013 - 10:02 PM
I posted the following a day or two ago in my thread for my Case 444 (K321):
"If Niagara Falls is a fitting name for your fuel pump.....does it need to be rebuilt? frown1.gif I started the Case yesterday to move her around a bit and out poured fuel all over the floor. Upon closer inspection I noted that the seals were shot."
Tonight I rebuilt the fuel pump and here's what happened:
http://gardentractor...actor/?p=337397
Any help you might be able to offer in the thread above would be appreciated. Thanks.
Edited by Moosetales, July 02, 2013 - 10:02 PM.
#2 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted July 02, 2013 - 11:50 PM
Even though I answered to your other post. I just wanted to add that I am a fan of rebuilding these old pumps. The biggest problem I have seen is the disks getting gummed up or something lodged in them holding them open. So if you have good diaphragms and gaskets I would rebuild it again (IMO)
  • Moosetales said thank you
#3 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted July 03, 2013 - 06:16 AM
It sounds like the pump is dead headed either internally or by an external blockage and is building pressure until the weakest part gives out. Personally, I'd try once more to find the problem and rebuild it then if that didn't work I'd go for a new one or an electric pump.
