* * * * - 12 votes
295 replies to this topic
#226 Brando OFFLINE
Brando
  • 339 Thanks
  • 331 posts
Posted September 10, 2014 - 08:08 AM
Here's my Sears 3pt hitch and Sears plow, eventually it will all get restored.
Thanks to everyone who shared a lot of nice pieces added to my wish list after reading this thread.
  • MH81, johndeereelfman, Coventry Plumber and 2 others have said thanks
#227 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted September 14, 2014 - 10:41 AM
Hi , made this scoop 2 weeks ago to remove dirt & silt from the old dry dam for garden fertilizer & to cover some open flat rock withPB250224.JPG when it was part done & when it was finished  ( works well for a simple job. needs to be painted yet PC210046.JPG & some dirt i have shifted all ready PC210044.JPG
  • MH81, Alc, KennyP and 3 others have said thanks
#228 Ron Dziedzic OFFLINE
Ron Dziedzic
  • 83 Thanks
  • 114 posts
Posted September 27, 2014 - 10:16 AM
Ok this is my favorite attachment not the best pic of it behind a yard man mtd lol but it's my jd yard trailer I made 10in. Cedar sides and welded the little wheels inside of two spare donut tires for more ground clearance and for easier mobility. I use this trailer at least a couple times a week for dumping my bager and it helps save a lot of time running back and forth to dumping my next project on the trailer is going to be a cover to make it so I can blow grass clippings straight into the trailer ( not with the yard man) lol
  • limebuzz, MH81, Alc and 4 others have said thanks
#229 firefight100 OFFLINE
firefight100
  • 20 Thanks
  • 19 posts
Posted October 02, 2014 - 07:55 PM
I havent seen a gt flywheel ditcher.  Does anyone have one they made?
#230 KennyP OFFLINE
  • 37,551 Thanks
  • 45,533 posts
Posted October 05, 2014 - 07:55 AM
Guess I need to add in my 2 latest homemade attachments!
First is my grader blade. This took a bit to figure out how to make it all work under the FF. But it's done other than paint. It has swing both directions as well as tilt. I need to sharpen the cutting edge a bit so it will cut grass better, but other than that I am very happy with the results.
Next is the single shank ripper/garden furrow tool. I haven't tried it out on the FF with down pressure as yet, but I think it will work fine for it's intended purpose.
#231 Rock farmer OFFLINE
Rock farmer
  • 1,197 Thanks
  • 1,232 posts
Posted October 05, 2014 - 04:19 PM
" I need to sharpen the cutting edge a bit so it will cut grass better,"
Looks like You already shaved a good swath of your lawn down bald! LOL
  • KennyP and holdenboy1960 have said thanks
#232 KennyP OFFLINE
  • 37,551 Thanks
  • 45,533 posts
Posted October 05, 2014 - 04:39 PM
That wasn't the well established stuff! Doesn't like that too well!
  • Rock farmer and holdenboy1960 have said thanks
#233 OldBuzzard ONLINE
OldBuzzard
  • 6,987 Thanks
  • 4,784 posts
Posted October 06, 2014 - 04:43 AM
Added two more attachments.
First is a duplicate of one I already had, another Dual Wheel Kit for the Bolens Large Frames.
The second is a mid-mount grader blade for the Large Frames
There is some discussion as to whether it's commercially made or home made.  The seller, and two of us that have actually seen it believe it to be commercially made.  Others that have only seen the pics believe it to be home made.
  • MH81, Alc, johndeereelfman and 5 others have said thanks
#234 toppop52 OFFLINE
toppop52
  • 5,039 Thanks
  • 4,644 posts
Posted October 06, 2014 - 07:51 AM
Looks like a machine shop build to me, a little better than backyard fab and not as smooth as mass production factory, either way it's a great unit.
#235 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted October 11, 2014 - 03:42 AM
The Scoop is home made & can be detached from the lift arms or be removed altogether from the machine .the scoop is 3ft x 1ft x1 ft
  • MH81, Alc, tractorgarden and 4 others have said thanks
#236 FixItCharlie ONLINE
FixItCharlie
  • 518 Thanks
  • 337 posts
Posted October 29, 2014 - 09:20 PM
I have 2 attachments that have put together. The first one is a grill guard, what make this an attachment is that it gives the ability to add weight on front of tractor. Grill Gaurd.jpg
The second is a rear scoop. Rear Scoop.jpg The bucket is something that my dad had gotten several years ago. I had tried several different ways to use it. When I got the LGT 145 with hydraulic lift & made the receiver hitch, I decided to set it for a rear mount. The one problem is getting the latch working properly, but I think that it should work correctly now. I have not painted it because recently just finished & fall temperature have not helped. One thing I found though is if I load to much dirt the hydraulics will not raised it with out dumping some out.
Charlie
  • MH81, Alc, KennyP and 5 others have said thanks
#237 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted November 02, 2014 - 08:14 AM
the weight lift thing was my concern , that's why i used the boat winch for , a bit slower but works ok for me . The rear concept of a scoop never really appealed to me , so is it easy to use on the rear as you have it ? putting aside the lift prob
FixItCharlie
#238 FixItCharlie ONLINE
FixItCharlie
  • 518 Thanks
  • 337 posts
Posted November 02, 2014 - 11:53 AM
No I have no problem with it on the back of the tractor. I spent many hours on farm tractors pulling equipment through the field where you need to watch things on both ends of the tractor. As for the lifting issue the snowblowers for these tractors use a spring assist for raising them. So I may look at doing something like that or some other ideas, but with the bucket only half full I can still move a lot more material with this then I can with a shovel. There are other things I can use to move that it has no problem lifting. There are times when extra weight is needed on the front of the tractor, so that is when the weight brackets become handy.
Charlie
#239 Pager450n OFFLINE
Pager450n
  • 385 Thanks
  • 369 posts
Posted November 07, 2014 - 09:09 PM
Heres my almost complete list of factory and home altered/made
factor 35A tiller with pto
54" 4 way blade
ripper
Gravely 44" powerbrush on my 400. Just needing new brushes
Also have a a potato plow, moldboard, toolbar, raised bed maker, 3 point scoop, project wood chipper, and possibly a manuer spreader.
  • MH81, Alc, johndeereelfman and 2 others have said thanks
#240 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted November 08, 2014 - 06:29 AM
I would love to make more attachments but got no real room to use them
